Mean little 4 cyl.
GMAC 76
Re: Mean little 4 cyl.
Post by GMAC 76 » Wed Jan 04, 2017 5:57 pm
Rich863 wrote:Pe 90 with 520 cyl one bad ass motor
especially if them 520's are GITSO cyls....that makes one rank little engine for sure
Davie GSO480
Post by Davie GSO480 » Wed Jan 04, 2017 7:28 pm
0-360
with 0-541 cylinders
built by Thurman
I dont know how to make picture bigger
Proud member of the Airboat Association of Florida.
A Miami Landmark sense 1951
http://www.aaof.com
Davie GSO480
Post by Davie GSO480 » Wed Jan 04, 2017 7:30 pm
http://www.aaof.com
pirate
Post by pirate » Tue Mar 28, 2017 3:40 pm
pirate the 541 cylinders are a completely different animal. they are same bore and stroke but the flange location is different on the 541 it moves the cylinder head closer to the block creating more compression. however they are not just a bolt on and go. they have to be modified to work right. whe done you can make big power with big compression and the heads are fairly tough.
Justin, PM sent
rowdy1
Post by rowdy1 » Wed Apr 18, 2018 10:34 am
Its been a while but I'm back on this project. I found a complete o290 that needs a little work. Can you put o360 or o540 cylinders on the o290 case?
SeatCover
Post by SeatCover » Wed Apr 18, 2018 5:51 pm
The cases have to be bored to accept the bigger jugs. And a 290 crank would make a 320 inch motor when using 540 or 480 jugs. O 435 jugs will fit but 435s are not know for a lot of power
rowdy1
Post by rowdy1 » Wed Apr 18, 2018 9:28 pm
So the next question is: Is it worth doing? Can I get 150 hp out of it? Again, I am wanting to build a "sporty" little deck over ride boat.
AirRacer25
290 to 320 conversion
Post by AirRacer25 » Mon Apr 23, 2018 3:29 pm
Hey Fellows
I am looking for someone that can bore my 290 case to accept 320 cylinders.
Got any recommendations?
Mike
Cm3gator
Post by Cm3gator » Tue Apr 16, 2019 8:27 pm
What about rig a trailer with sides that drop? Drive onto trailer, in normal fashion. Turn left, drive off. As we say, it's all in the rigging.... Think that would work?
Making the Swamp Great Again.....
:rebel: :old_glory: :florida:
12' Gilleo SV 0-360, L72Q
onearmedbandit
Post by onearmedbandit » Thu May 02, 2019 9:08 am
Check info about Bad attitude race boat. I have the engine. 0360 with continental 0520 cyl. Will sell
