200 angle valve
Macdog
200 angle valve
Postby Macdog » Tue Jan 03, 2017 4:48 pm
Is there one 200 angle valve better than the other? How can you tell if it's a true 200 angle valve?
pirate
Re: 200 angle valve
Postby pirate » Tue Jan 03, 2017 8:13 pm
That's two different questions.
If you are asking is one Lycoming O-360 series 200 hp engine better than any other Lycoming O-360 series 200 hp engine what do you mean by better?
As to the second question. You can believe Lycoming spec's or you can put it on a dyno.
For instance, I have a O-360 series engine that with the set up I have I've been told by a reputable builder that it should develop 220/225 hp at 2950/3000 rpm. Do I know that for sure. No
Waggs
Re: 200 angle valve
Postby Waggs » Wed Jan 04, 2017 8:35 pm
Do you turn the same prop as a GPU???...
Liberty Mechanical Services
321-689-7709
Make America Cool Again!
KCCO
pirate
Re: 200 angle valve
Postby pirate » Wed Jan 04, 2017 9:53 pm
I don't have a clue what a GPU turns.
At present my engine turns a 68" 5 blade Razor prop set at 7 degrees 32 hundred rpm. I need to add a couple of degrees to get it to 2950 on the trailer or approx. 3000 rpm on the water
pirate
Re: 200 angle valve
Postby pirate » Sat Jan 07, 2017 4:10 pm
Waggs wrote....Do you turn the same prop as a GPU???...
Not sure what HP GPU you're talking about but is that close to what a GPU turns?
todd glover
Re: 200 angle valve
Postby todd glover » Sun Feb 12, 2017 9:15 pm
My old 200 had high comp cold air intake and total seals spun 68x36 paddle 2950
