Lycoming phase 3 cam 0540 heeelp
xeyes
Postby xeyes » Mon Jan 09, 2017 3:31 pm
Hello folks,
I'm looking for a phase 3 cam for an 0540. D and S can grind the H290 but Larry does not have the master profile for the Phase 3. Who elso out there can grind one for me.
Thanks Ben
Re: Lycoming phase 3 cam 0540 heeelp
Postby kwanjangnihm » Mon Jan 09, 2017 6:17 pm
pirate
Postby pirate » Mon Jan 09, 2017 6:36 pm
Not sure but you might try Jurnigans. They can do almost anything. If not they can probably send you in the right direction.
xeyes
Postby xeyes » Wed Jan 11, 2017 12:00 pm
I'm going to stay with the stock 75190 cam, Jurnigans said the phase 3 cam performance range is around 3000 rpm. For my aplication in an aircraft anything over 2750 just makes more noise.
Thanks All,
HAMMERHEAD
Postby HAMMERHEAD » Tue Jan 24, 2017 8:46 pm
H290 for that RPM range is the best cam you can get IMO
Users browsing this forum: Baidu [Spider] and 4 guests
