220 mechanical fuel pump
TDezso
Postby TDezso » Wed Jan 11, 2017 8:43 am
Just got this boat on the water and the electric pump took a crap on me 5min on the water. Checked out the factory pump to see if it was usable and it's internals are junk. I did some searching and found the pump from a late 70s dodge works and I picked one up. So I noticed the lever doesn't ride on the shaft like it is supposed to. It has about 1/4" gap. Is there another option for a pump besides factory? Maybe an aftermarket performance pump like Holley or edelbrock?
Re: 220 mechanical fuel pump
Postby John Fenner » Wed Jan 11, 2017 9:15 am
1984 Plymouth horizon 2.2 fuel pump works. You can also get an overhaul kit for the factory Carter pump and rebuild it.http://www.zip-corvette.com/56l-57-fuel ... oCr9Pw_wcB
TDezso
Postby TDezso » Wed Jan 11, 2017 9:31 am
Thanks for that link. I think my pump needs the brackets that hold those baskets in. I wonder what the difference is between the horizon pump(#60321) and the valiant pump I got (#60577). I just don't like the way the lever rides on the shaft. I feel like it's going to wear it out betting on it instead of riding on it.
Postby John Fenner » Wed Jan 11, 2017 12:21 pm
Beating on it vs riding on it, you aren't getting full throw from pump, heat the arm and bend it to where you have zero lash and a slight preload on lever.
TDezso
Postby TDezso » Wed Jan 11, 2017 1:27 pm
It doesn't have much throw in the pump. I think if I bend the lever, it's gonna want to pass the bottom out position. The stock pumps seem to have a lot more throw for the size of the lobe on the shaft. This pump seems to be run on a smaller lobe. Maybe I'm not making sense when I'm typing. Lol
Gary S
Postby Gary S » Thu Jan 12, 2017 6:53 am
John, will that kit work with Lycoming fuel pumps?
Postby John Fenner » Thu Jan 12, 2017 8:42 am
No sir, lycoming is of much different design, these are from 56/7 corvette, Holley sold them as high volume pumps.
Gary S
Postby Gary S » Fri Jan 13, 2017 7:22 am
Just wondering, have you ever found a rebuild kit for Lycoming?
Postby John Fenner » Fri Jan 13, 2017 12:20 pm
Not yet but might be something to look into.
