MA-4-5 carb/engine application
GMAC 76
Postby GMAC 76 » Mon Jan 23, 2017 10:38 am
does anyone have any carb to engine info on a MA-4-5 carb part number 10-2513 or 2518 ( hard to read tag)....I have no info on this carb in any of my papers or books....thanks
pirate
Re: MA-4-5 carb/engine application
Postby pirate » Mon Jan 23, 2017 11:16 am
Try this link and contact them. Good luck.
http://msacarbs.com/10-59923.html
pirate
Postby pirate » Mon Jan 23, 2017 1:33 pm
PM sent
Raymond Mott
Postby Raymond Mott » Mon Jan 23, 2017 6:57 pm
Kinda curious what you find out. As I have the same carb.
12x7 Red Rebel hull, 170 angle valve, 68" Q
If I can't have fun, I don't want to go!
GMAC 76
Postby GMAC 76 » Mon Jan 23, 2017 7:19 pm
Raymond Mott wrote:Kinda curious what you find out. As I have the same carb.
according to marvel schebler rep the 10-2518 is a military number for the carb on the go-435 Lycoming engine...mid 1940's
krazymatt
Postby krazymatt » Tue Jan 24, 2017 5:48 am
I have same carb on my o-435. Runs good. My motor is a apart and a buddy has been running it on his go-480 with no issues...
GMAC 76
Postby GMAC 76 » Tue Jan 24, 2017 10:06 am
this carb is on an AV 540 and the engine seems to just not be the horse it should be .....knowing what I know now IMO it is not enough carb for that engine to preform properly and needs a 540 carb
fhp6
Postby fhp6 » Tue Jan 24, 2017 6:31 pm
If the MA4-5 isn't for an O540, what is the correct carb for the AV540?
:old_glory: FHP6
Citrus County Airboat Alliance (Member)
"USMC"
:florida:
GMAC 76
Postby GMAC 76 » Tue Jan 24, 2017 6:51 pm
first the AV-540 was a fuel injection engine many guys opt out for a carb instead of the FI SO the correct carb for the AV-540 Lycoming is an MA-4-5 for an 0-540...... the 540 versions have a larger throttle bore, throttle valve and venture....easiest way to tell is by the throttle valve (butterfly) stamped number a 14-277 is the 0- 540 carb ...the 14-187 is the other MA4-5 which fits a large variety of engines...this carb has the #187...so imo will not run the AV 540 to its full potential
twister69z
Postby twister69z » Wed Jan 25, 2017 2:38 pm
Still looking for a 10-4404?
GMAC 76
Postby GMAC 76 » Wed Jan 25, 2017 3:07 pm
twister69z wrote:Still looking for a 10-4404?
I will know the answer to that after I explain all this to the owner to see if he wants to "do it right".....he is also not turning enough prop for his engine......... 70" narrow blade whirlwind on a AV 540...WHAT!!!!
pirate
Postby pirate » Wed Jan 25, 2017 5:08 pm
According the information I have, the MA 4-5 10-4404-1, 10-5054, 10-5042, 10-6035-11, and 10-5045 are also designated for the O-540 series engine. The MA-6AA 10-4975, and10-4218-1 are installed on the VO-540 (vertical) engines.
GMAC 76
Postby GMAC 76 » Wed Jan 25, 2017 5:44 pm
good info pirate....I had forgotten about the 6AA carbs for the 540's
fhp6
Postby fhp6 » Wed Jan 25, 2017 7:42 pm
Great info... thank you Pirate!
:old_glory: FHP6
"USMC"
:florida:
Users browsing this forum: No registered users and 6 guests
