220 burning oil?
TDezso
220 burning oil?
Postby TDezso » Tue Jan 31, 2017 7:33 pm
Going through oil in my 220 like crazy. Smokes out the right side quite a bit. Especially after loading on the trailer. Compression test showed 120,130,130 on that side. Plugs look like crap all the way around. What could be the issue? Ran out of daylight, gonna do a leakdown tomorrow.
luv2airboatnhunt
Re: 220 burning oil?
Postby luv2airboatnhunt » Tue Jan 31, 2017 9:01 pm
I had a 220 ran great, but started to use oil "like crazy". After disassembly, I found previous owner had used steel oil rings on steel cylinders. Which is common on gpu's for their intended purpose, but they won't last with the higher rpm's and heat generated on the airboats. Works great for a short time. I did a 470 conversion for the rebuild and eliminated that issue. Do you know the history on the rings, motor?
TDezso
Postby TDezso » Tue Jan 31, 2017 9:26 pm
I have no clue about the history. What rings should I use and where can I find them? How do people not have problems just slapping new jugs on motors?
jeepinocala1111
Postby jeepinocala1111 » Wed Feb 01, 2017 6:27 am
Post a picture of the boat or engine maybe someone here knows a bit about it.
TDezso
Postby TDezso » Wed Feb 01, 2017 7:27 am
It came from Jacksonville Florida area.
Users browsing this forum: Google Adsense [Bot] and 1 guest
