IO-0470 PUSHROD TUBE SEALS
flcracker9
Postby flcracker9 » Sat Feb 11, 2017 6:10 pm
Any tricks to replacing the pushrod tube seals on the center cylinder? I can fabricate a tool to fit over the tube so I can push it in and compress the spring, bit it looks like a royal pain to reach them? I'm assuming at least the intake must come off? I already replaced the ones closest to the prop, and to get to the rear intake bolts I had to cut down a socket, and use a wobble extension just to get the rear intake bolts. Just checking to see if anyone had any tips to make it easier to replace the center tube seals!
cowboy
Re: IO-0470 PUSHROD TUBE SEALS
Postby cowboy » Sun Feb 12, 2017 8:17 am
Some have successfully used ty-wraps to compress the spring during assembly, in some instances. I have never done it myself. Twist tightened wire loops might suffice to compress the springs. Worth a try anyway.
flcracker9
Postby flcracker9 » Sun Feb 12, 2017 2:56 pm
cowboy wrote:Some have successfully used ty-wraps to compress the spring during assembly, in some instances. I have never done it myself. Twist tightened wire loops might suffice to compress the springs. Worth a try anyway.
Thanks for the reply Cowboy. I did use ty-wraps to do the front cylinders. Compressed the springs in my bench vise, installed the ty-wrap, slid over the tube, reinstalled and cut the ty-wrap. It did work, but there was more room on the front cylinder than the middle. In looking at it, I definitely need to remove the intake to get any kind of clearance to remove the tubes on the center cylinder. I was looking for any helpful hints on removing the back intake bolts, so I can access the pushrod tubes. It was much easier on my 4cyl Lycoming!!!
twister69z
Postby twister69z » Sun Feb 19, 2017 9:56 pm
Snap on brand 1/4 12 point swivel socket . 7/16 hold your mouth just right!
Twister69z
Looking my pictures for 3 pictures of tools we use to install the tunes.
flcracker9
Postby flcracker9 » Fri Mar 10, 2017 3:12 pm
I ended up making a tool to compress the tube springs (worked great), and I was able to get to the rear intake bolts with a 7/16' socket cut down, on a wobble extension. I painted the cut down socket red, tossed it back in my socket drawer for future use/indentification.
Thanks for the replies!
Lwells
Postby Lwells » Sun Mar 12, 2017 9:31 pm
I'm pretty sure you can go to an aircraft tool or supply company and buy special tools to do the job easily. Not sure
Users browsing this forum: Google [Bot] and 2 guests
