0320 h2ad
fishnhunt80
0320 h2ad
Postby fishnhunt80 » Mon Feb 20, 2017 7:32 pm
I have a 10 ft hull with o320 h2ad what prop should i look into getting this is my first aircraft powered boat
Re: 0320 h2ad
Postby Deano » Mon Feb 20, 2017 8:40 pm
Were it me, I would get a 70" Water Walker Cypress series.
Call them and talk to Andrew, I'm pretty sure he will confirm that size. And take your order. :)
fishnhunt80
Re: 0320 h2ad
Postby fishnhunt80 » Mon Feb 20, 2017 8:58 pm
thanx
diamondback0320
Re: 0320 h2ad
Postby diamondback0320 » Mon Feb 20, 2017 11:42 pm
I've run both the 70in & 68in powershift with cypress blades on 2 different h2ad boats & trust me they both performed well.. I'm running the 68in now & i like it a smidge better for the snap..on this boat anyhow!
fishnhunt80
Re: 0320 h2ad
Postby fishnhunt80 » Tue Feb 21, 2017 6:56 am
How do u like the h2ad engine
rick
Site Admin
Re: 0320 h2ad
Postby rick » Tue Feb 21, 2017 11:18 am
I ran an h2ad on a 12' Hamant for a few years. Mine had a 68" Sensenich 2 blade h on it and ran it the same places I run my current 6 cyl. boat.
Keep it light and drive it right and it'll surprise you where you can go with it.
Only problem I had with mine was moisture in the mag. Almost seemed like it created it own moisture sometimes and I'd have to take time to dry it out downriver. I've been around other H motors that didn't seem to have that problem though.
Rick
diamondback0320
Re: 0320 h2ad
Postby diamondback0320 » Tue Feb 21, 2017 11:54 am
yep just like rick said these things seem to have moisture & ground problems in the mag..my 1st h2ad didn't have those problems but this 1 has cpl times..another thing thats very important is to make sure to keep good clean oil in it!! they tend to have cam & lifter problems.. I've had to replace lifters on both motors..bout every 3 -4 oil changes i inspect all the lifters..if i find any with pitting or galling on the face i replace them..either use camguard in your oil or you can buy the victory Phillips aviation oil with the lycoming cam additive already in it which is what i run
Waggs
Re: 0320 h2ad
Postby Waggs » Tue Feb 21, 2017 2:04 pm
I've been running a 72" Wisper tip Narrow blade. It's but pushes good. The reason for the long prop is I had aspirations to supercharging this motor and never got around to it. Still did purty durn good. M
She's recently had her last run as the oil pressure won't rise above about 10 psi. Likely due to the cam and lifter problem.
I did have a mag problem one time, just need to try and keep it covered when stored.
I've run the dog mess out of that motor for about 10 years, only that one mag problem and 2 times burned a valve from running to hard on pump gas. Other than that, it's been a work horse.
Liberty Mechanical Services
321-689-7709
Make America Cool Again!
KCCO
jopete
Re: 0320 h2ad
Postby jopete » Tue Feb 21, 2017 3:29 pm
I ran 0320h2ad for 2 or 3 years on a 10' home made alum hull.. it was my first airboat. it came with a 'cut down' power plus 2 blade. it had top end for days but suffered on low end grunt. [blades were wide]
I switched to a 68'' 2 blade cypress series prop and the boat was snappy, turned ALOT better in deep water, and ran the ground a lot easier. never had mag condensation problems with it, probly should of never sold it, but made a good deal on a 15' car motor boat.
fishnhunt80
Re: 0320 h2ad
Postby fishnhunt80 » Tue Feb 21, 2017 6:59 pm
Thanx only av gas has ever been ran it i got it from a close friend ill ask him about the condensation see if its ever happened to him while running it
fishnhunt80
Re: 0320 h2ad
Postby fishnhunt80 » Tue Feb 21, 2017 7:01 pm
Whats the price range to do a complete overhaul on the h model i have always ran carmotor but for what i got in this boat u couldnt buy a running carmotor out of a junkyard :)
Users browsing this forum: Google Adsense [Bot] and 1 guest
