220 rering
TDezso
220 rering
Postby TDezso » Tue Feb 21, 2017 2:56 pm
Does anyone know the ring gap for a 220 standard bore?
Re: 220 rering
Postby Deano » Wed Feb 22, 2017 9:21 am
Here is a link to the overhaul manual if you need additional info:
http://www.southernairboat.com/pdf/aircraftengines/continental/gpu/PE-150-OH-Manualpdf.pdf
TDezso
Re: 220 rering
Postby TDezso » Thu Feb 23, 2017 8:01 am
Awesome. I looked through the manual and didn't see that pic.
Re: 220 rering
Postby Deano » Thu Feb 23, 2017 8:50 am
The clearance and tolerance data is all the way in the back.
I believe that info is on Manual Pg 145, which is PDF file pg 147.
TDezso
Re: 220 rering
Postby TDezso » Thu Feb 23, 2017 9:26 am
Found it. Thanks.
