220 gpu
Bobbyskin1975
220 gpu
Postby Bobbyskin1975 » Mon Feb 27, 2017 6:51 pm
Where can I get rebuilt loaded jugs and what is the around about price per jugs
diesel250rr
Re: 220 gpu
Postby diesel250rr » Mon Feb 27, 2017 7:04 pm
What's wrong with yours
Re: 220 gpu
Postby Deano » Mon Feb 27, 2017 7:17 pm
You might try Gary Barber @ Outlaw Aircraft Engines.
Bobbyskin1975
Re: 220 gpu
Postby Bobbyskin1975 » Mon Feb 27, 2017 8:24 pm
No sure if anything is wrong with them just trying to get a lead on where they can be gotten from I'm going to take it apart and see but it has a lot of blow by but I was told it's probably the pistons and rings that the jugs hardly go bad? Do know a lot about them this is my first one.
diesel250rr
Re: 220 gpu
Postby diesel250rr » Mon Feb 27, 2017 9:26 pm
Had mine rebuilt 1700 from my motor never put back on from an aircraft overhaul place in south florida don't know what was done gave them pistons and jugs complete with valves and springs got everything back in bags and never used them found I had a bad crank just info for you
Bobbyskin1975
Re: 220 gpu
Postby Bobbyskin1975 » Mon Feb 27, 2017 11:07 pm
Thanks
Users browsing this forum: Google Adsense [Bot] and 1 guest
