rebuild a 220
blowboatbandit
rebuild a 220
Postby blowboatbandit » Tue Feb 28, 2017 3:16 pm
2 years ago I left my boat with a guy to rebuild my dual mag pe-150 470 angle valve motor that spun a rod bearing. I wanted a std-std crank installed which took a while to find. anyways guy has some problems and is giving me my boat back,soon I hope. Looking for someone that can rebuild the lower end in a timely and professional manner. if guy is good on his word, hes giving me the std crank and some other things as well. top end has 17hr on it if I remeber correct.
Doing what I do best.. showing off..
Re: rebuild a 220
Postby Deano » Wed Mar 01, 2017 8:31 pm
You might try calling Tom Jeffords and talk to him.
He's Speed Wheelie on this board. I believe his number is 863-956-3030.
blowboatbandit
Re: rebuild a 220
Postby blowboatbandit » Thu Mar 02, 2017 1:35 pm
Thanks..
glades cat
Re: rebuild a 220
Postby glades cat » Thu Mar 02, 2017 2:38 pm
Tom Jeffords is a great person and top notch mechanic. He's done work for me and I drove 4 hours to see him. Top shelf for sure. Speed Wheelie is a go to guy. The work he performed has lasted years without a flaw.
