Io520 injector line help
titan
Postby titan » Mon Mar 06, 2017 11:10 pm
Does anybody know where and what size line I can replace these hard lines to the injectors they keep breaking. Is there a website that sells them?
GMAC 76
Re: Io520 injector line help
Postby GMAC 76 » Tue Mar 07, 2017 8:07 pm
If ya have the part numbers..... search preferred airparts.....they have a lot but ya have to have the part numbers!!!!
flcracker9
Postby flcracker9 » Fri Mar 10, 2017 2:59 pm
If you have a shop near you that specializes in hydraulic hoses, they can probably make braided steel ones (using your old ends). braided lines are a little more vibration friendly. We have a local shop down here that has made them like that, maybe others will chime in?
DAVE C
Postby DAVE C » Sun Mar 12, 2017 10:21 am
IF YOU BEND THEM TO TRAVEL ALONG PUSHROD TUBES AND PUT SECTION OF SMALL DIAMETER RUBBER HOSE OVER LINE WHERE IT GOES ABOVE PUSHROD AND ZIP TIE DOWN. TAKES CONSTANT VIBRATION OUT THROUGH RUBBER.SMALL DIAMETER FUEL LINE OR HEAVY VACUMM LINE WORK S BEST.
