Adjusterble push rods
riverrat1
Post by riverrat1 »
I've got a 0-470 and it has adjustable push rods , what is the lash adjustment on the valves , Hot or Cold
TDezso
Re: Adjusterble push rods
Post by TDezso »
From what I've been told .060-.090 bottom dead on the lobe with lifter compressed. And set as close as possible to each other.
Sent from my iPhone using Southern Airboat
Post by kwanjangnihm »
Gary uses adjustable push rods in some of his rebuilds - give him a shout - info below. :thumbleft:
Gary Barber
Outlaw Aircraft Engines
www.outlawaircraftengines.com
863-698-0383
