O-470-15
Tread
O-470-15
Post by Tread »
I Bought an oil temp sensor for to install on my oil sump drain port. Everywhere I read said it was 5/8 NPT on o-470.
Well an O-470-15 is older and has a completely different sump.
5/8 was way too small.
I am looking for an adapter fitting that will replace my drain plug.
I removed the plug and took it to NAPA, it doesn't match any NPT fittings!!
The IPB reads brass hex head 1-14.
Is that the thread pitch?
Where can I find a fitting to match?
ffjpowell
Re: O-470-15
Post by ffjpowell »
Try Aircraft parts store in Jacksonville florida.
9049989101
Sent from my SM-N920P using Southern Airboat mobile app powered by Tapatalk
What the mind of man can conceive and believe, the mind of man can achieve.
Live today like theirs no tommorrow.
New build on the way!!!!!! Stay tuned.
J. Powell
406 JAMIE
Re: O-470-15
Post by 406 JAMIE »
try a hardware store with brass fittings to find a reducer or go to home depot or lowes plumbing sections and see if u can find something to work or take oil pan to machine shop and have them weld in a bung like o2 sensor so u can screw it into place.hope this helps besafe y all :rebel:
TDezso
Re: O-470-15
Post by TDezso »
I just picked up a -15. How are you doing your mounts?
Sent from my iPhone using Southern Airboat
