GPU accessory case on E185?
TDezso
Post by TDezso »
About to swap to the 185 motor and the mags sit way higher than on the gpu where they sat under my rear seat. I hear the gpu case can be used on the E185. What has to be done to swap them and what has to be machined? Is it worth the work?
Re: GPU accessory case on E185?
Post by John Fenner »
Yes, I have done it, basic modification to start with bit tricky part was machining oil pressure relief valve into cover, the rest is like doing a dual mag conversion on a gpu, you will need to machine a crank gear spacer out of .125 aluminum and use a 220 crank and cam gear plus mag drive gears and pins, accessory drive oiling will need to be rerouted vs through different portal than at top of block, custom gasket will need to be made and then of course a sump.
TDezso
Post by TDezso »
John Fenner wrote:Yes, I have done it, basic modification to start with bit tricky part was machining oil pressure relief valve into cover, the rest is like doing a dual mag conversion on a gpu, you will need to machine a crank gear spacer out of .125 aluminum and use a 220 crank and cam gear plus mag drive gears and pins, accessory drive oiling will need to be rerouted vs through different portal than at top of block, custom gasket will need to be made and then of course a sump.
Thanks for the info. Turns out the motor I picked up isn't a 185, it's an 0470-15. I was hoping to get the mags to sit under the seat like the gpu did. Might not happen though.
Get with Cecil Field and get an e185 front cover plus gears, it's not that bad of a job.
TDezso
Post by TDezso »
John Fenner wrote:Get with Cecil Field and get an e185 front cover plus gears, it's not that bad of a job.
What kind of work is involved with swapping the 185 cover?
You don't need to do the pressure relief valve modification
Once all is set in place you will need a set of transfer punches for bolt hole locating to case
