Lots of 0470 questions.
TDezso
Postby TDezso » Tue Apr 11, 2017 8:08 am
Putting together an 0470-15. This is really my first aircraft motor, besides replacing jugs on a 220. So I've got questions. First is, what do I need on this case besides the mags obviously? And what do I need to block off? I seem to be missing the tach cable mount it looks like also. I haven't really looked at enough of these motors to be able to just bolt everything on. Image
Tread
Re: Lots of 0470 questions.
Postby Tread » Wed Apr 12, 2017 9:41 am
You will need a fuel pump, starter, and a tach generator mounts between your Mags. Everything else I have blocked off on my -15
Postby Deano » Wed Apr 12, 2017 12:12 pm
Don't know if you were aware of this or not . . .
but there is a manual right here for that engine:
http://www.southernairboat.com/pdf/aircraftengines/continental/470/Continental_0-470_15_O.pdf
If you right click on that link and then select "Save target as ...." you can download it and have a copy.
TDezso
Postby TDezso » Wed Apr 12, 2017 2:16 pm
Deano wrote:Don't know if you were aware of this or not . . .
I've looked through them. I've got them saved and am waiting on parts to get it done and on the boat.
Users browsing this forum: No registered users and 7 guests
