Covering poly bolts in a glass hull?
CypressHunter
Post by CypressHunter »
I've been thinking about doing a complete overhull to my glass boat. I want poly. Only running steelflex now. The "BOSS" aka my wife does not want my to poly the bottom because does want my daughter or her wanting on bolts. I was trying to think of ways to cover the bolts. Either sea deck or some other form of padding. I even saw an old post on here were Twister buck riveted them. All input is appreciated
CypressHunter
Re: Covering poly bolts in a glass hull?
I meant to post this in Airboat Tech
twister69z
Post by twister69z »
I would rivet them and you won't have leaks ,also the button is easy on the feet!
twister69z
Private message me if you need any more info on it!
CypressHunter
twister69z wrote:Private message me if you need any more info on it!
Already did. I saw your YouTube video but still haven't got a response
twister69z
I have not received any private messages , ask away !
CypressHunter
I re-sent it
twister69z
Did you get my reply?
CypressHunter
I did thank you. Hull turned out to be a POS. Exploring other options
