can anyone tell me what motor this is
codydibella
Post by codydibella »
I got this motor from a guy that had it in his garage for a few years. I was able to get it running and it sounds pretty good too. Im just hoping that someone can help identify this engine. I can get more/better pictures if needed. Also there is some play in the crankshaft, not only when I rotate back and forth but also pushing the crank in and pulling out it will move, doesn't seem normal to me...
406 JAMIE
Re: can anyone tell me what motor this is
Post by 406 JAMIE »
there should be a plate on intake i think with id numbers and specs.
If i had to guess its got angle valve heads like my old io 540.but it looks like a 180/200 lycoming.
Try to find any numbers u can and goggle them should lead u to some info hopefully.hope this helps and there r some great AC guys on this site so hopefully they will see and help :thumbleft:
Y all plz besafe. :rebel:
digginfool
Post by digginfool »
Looks like a Lycoming O-360, angle valve, narrow deck. Was probably rated at 200 hp.
DuckNutt
Post by DuckNutt »
Briggs and Stratton 5 1/2 horse. Bluebook about 105.00, I'll take it off yer' hands for 100.00 LOL
codydibella
Haha 150 and its yours ducknutt!
Thanks guys I will check again for any tags
terrible ted
Post by terrible ted »
codydibella wrote:Haha 150 and its yours ducknutt!
hell i give you 151
If its running good that should be a great little boat motor if its 200 hp.
helicsher
Post by helicsher »
It should push in and pull out a lil
"Success Requires No Excuses"
Black67
Post by Black67 »
I'm thinking 0320 because of the intake tubes look small in the pictures.
Sent from my SAMSUNG-SM-T377A using Southern Airboat mobile app powered by Tapatalk
Black67
Post by Black67 »
Sorry, I meant 0340 (170)
BonnetWalker
Post by BonnetWalker »
O-290G with o435 A/V would be my guess,around 140hp to maybe 150hp
swamp_fever
Post by swamp_fever »
it looks like the motor a friend of mine once owned with that oil block on top it was there to oil the lifters i was told o290 case had solid lifters with 0480 jugs about 165-170 hp did a pretty good job on the 10' franny taylor hull he had and a little play is normal in both directions
codydibella
Swamp_fever that sounds more like it. The guy I got it from told me about the lifters and the oil block but he didnt know what case and jugs it has. Thanks for the info
codydibella
Does this look like his old hull that engine was on?
swamp_fever
its similar to it i bought the franny taylor hull from him back in 1985 it needed a little work that he didnt want to fool with it he put the motor on a gore hull the last time i saw the boat his little brother had it that was about 1988
theres a picture of the f taylor in my pic gal after i fixed it up ( sorry dont know how to pull the pic from there to here)
tmetcalf1231
Post by tmetcalf1231 »
I would agree with BonnetWalker. The extra oil lines tell the tale I believe.
Sent from my SM-N900V using Southern Airboat mobile app powered by Tapatalk
Post by Deano »
I to, believe BonnetWalker to be correct.
It looks eerily similar to my 290, that has been retrofitted with 435 AV cylinders. My external topside plumbing is done out of hard line rather than flexible hose though. I don't know and/or can't see enough from those pictures to confirm or deny that possibility.
If you post a pic of the side view(s) w/o the flywheel it would aid in ID-ing the case.
If the prop flange is welded on the crank that is a dead give away it was a 290G (gpu) in its former life.
That does not work both ways though, since it could have got a 320 crank with the AV cylinders.
Moritz
Post by Moritz »
It is an IO-360 Lycoming Narrow deck -angle valve 200 hp
codydibella
My dumbass found the tag, cleaned it up and heres the info on it.. I guess now my question would be what jugs are these? From AV 435? 3 of the jugs have a number that reads 73869 and one jug reads 72224. Thanks guys.
codydibella
Doesnt the I in IO-320-E2A stand for fuel injected? How is there a carb on this intake?
406 JAMIE
Post by 406 JAMIE »
yes sir u r wright about the letter (I) being for injection.
Its like on my old io-540 had bendix fuel injection but some guys like the carb because its easier to work on.but that motor will make a great motor for ur boat and Sip Fuel :thumbleft: :toothy7:
Y all besafe out there :rebel:
406 JAMIE
Post by 406 JAMIE »
and that was the plate i was talking about sir. :thumbleft:
midnight rider
Post by midnight rider »
That is a 290 ground power case. Where the flange is cut around the crank gives it away. It was a solid lifter motor, hence the oil lines added. That sump is a common one people would add to those cases in order to put an up draft carb on it. Original had a downdraft carb on it. The tag on it has nothing to do with that motor. It also came with parallel valve cylinders. Unless the case was cut to take larger bore cylinders they are prob 0435 cylinders. They are great little motors, I've had two. But none the less they are a bastard motor with parts from many different series of motors.
Post by Deano »
midnight rider wrote:That is a 290 ground power case. Where the flange is cut around the crank gives it away. . . . .
Thank-you, Sir. :thumbleft:
codydibella
What kind of hp did the two that you had produce?
midnight rider
Around 150
