IO-720 Lycoming Fuel Injection Alternatives
Sjteuton
Post by Sjteuton »
I would like to get rid of the Lycoming Injection and go to something better. Any suggestions. I really don't want to spend thousands to do so. Can it be converted to an auto injection system? Let me know your thoughts?
GMAC 76
Re: IO-720 Lycoming Fuel Injection Alternatives
Post by GMAC 76 »
seen a 720 in Nebraska some years ago that had a real nice adapter welded up similar to the units they use on the SC480'S ....it was hooked up to the front of the sump intake with a 4 barrel carb mounted on top out in front of and in between the mags...seemed to work really well but man did that engine like the avgas
Sjteuton
Post by Sjteuton »
I wish someone had a picture of that. Not sure how this would happen. This motor is an upstack so it limits space unless you work between the fuel tank and the sump. The one thing I have already done which has been the best move since owning this motor is installing a pacemaker and getting rid of the 1200 series bendix mags.
GMAC 76
Post by GMAC 76 »
if I remember right the adapter on this 720 was bolted to the front of the sump where the servo bolted up...looked like 4-5" dia aluminum pipe tur
ned up 90 degrees with a plate welded to the pipe to accept the carb.....it was not an upstack but I don't know what difference the sump is on an upstack
Sjteuton
Post by Sjteuton »
The sump opening to the servo is facing the prop on the back of the motor. I will take some pics and post shortly. I think that will help tell the story.
Sjteuton
Post by Sjteuton »
Sjteuton
Post by Sjteuton »
GMAC 76
Post by GMAC 76 »
yes sir you are certainly right...maybe the difference between upstack and regular exhaust or the airplane or helicopter application of the engine...either way it sure wont work on your engine his carb was just a little forward of where the oil filter is on your setup....good luck to ya hope ya find a better way
CRACKERSTYLE
Post by CRACKERSTYLE »
Do you still have the 1200 series mags for sale?
John 3:16
Sjteuton
Post by Sjteuton »
No I sold them.
Sjteuton
Post by Sjteuton »
Could you use an aircraft carburetor on it if I built mounting tube for it? I wish I knew more about auto injection, I can't see why it would not work if it is electronic.
GMAC 76
Post by GMAC 76 »
I don't think any aircraft carb at least that I am aware of would handle 720 cubic inches....couldn't flow enough air or fuel...I have seen a super charged 480 engine that was equipped with dual MA-6AA CARBS side by side on a Y pipe into a single pipe up to the super charger
Dirtman
Post by Dirtman »
There is someone who works with Darin at Pacemaker ignitions who has been building electronic fuel injection systems for several 6 cylinder aircraft engines (both Lycoming and Continental) The people I have spoken to seem to be very satisfied with them. They have said they are very dependable and fuel economy has picked up considerably
GMAC 76
Post by GMAC 76 »
well I sure think if he could build them for a 6cy he could build it for 8 cyl.....might be a hell of an idea there
Sjteuton
Post by Sjteuton »
If it will get better fuel economy, I'm all for it. The sucker likes gas. I'll reach out to Darin tomorrow. Someone said they are really high priced, does anyone know what he is getting for a 6 cylinder system?
scottginfla
Post by scottginfla »
Sjteuton wrote:If it will get better fuel economy, I'm all for it. The sucker likes gas. I'll reach out to Darin tomorrow. Someone said they are really high priced, does anyone know what he is getting for a 6 cylinder system?
Any updates ?
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
Sjteuton
Post by Sjteuton »
I would love to have the injection system that Darren's buddy sells, I hear it is awesome. Out of my price range at the moment, building a house. My wife would shoot me over this purchase... Hmmm, house or fuel injection, can you spell divorce and alimony!!!!
Mike Thurman
Post by Mike Thurman »
CRACKERSTYLE wrote:Do you still have the 1200 series mags for sale?
I bought them.
Airboat Headquarters Inc.
Sensenich Propeller Dealer
Bud Marquis Supporter
woodlineO540
Post by woodlineO540 »
I went with the airflow performance feel injection system and I absolutely love it they are in South Carolina I dealt with Kyle day the other option is send your System to Southeast Fuel solutions Joey buyers really knows his stuff he goes by quick diesel on this site
Alvinlee1915
Post by Alvinlee1915 »
Upside about fuel injection is increased power and fuel economy. Downside is if something goes bad you better have the $ on standby to get it fixed. I like just having the carburetor. Easy to work on.
Pulfordanny
Post by Pulfordanny »
Does any one know where I can buy 1200 mags ? Thanks
