Cont 470
barhopper
Cont 470
Postby barhopper » Sun Aug 20, 2017 5:55 pm
Ok I need some help. I have a IO-470. It's been sitting for awhile. We cranked it up today. After warming up we only had between 5 and 10 psi oil pressure at idle. Around 30 at mid range. Couldn't wind it up because we had it mounted on a flat trailer. I've been searching the site for the answer to this question. I took the factory aircraft starter of and got an Airtec rear set up. Is there something else I need to block off to get the pressure up? The factory accessory case is still on. I just made a plate to close the factory starter hole. I removed the filter and half assed cleaned it. I removed the oil pressure relief valve. It seemed fine. Not adjustable just screws in and out. Any suggestions would be great. I don't know aircraft motors. It was supposed to be a recent rebuild before I got it but it had sat quite awhile.
barhopper
Re: Cont 470
Postby barhopper » Sun Aug 20, 2017 6:10 pm
A picture
barhopper
Re: Cont 470
Postby barhopper » Sun Aug 20, 2017 6:56 pm
JT540
Re: Cont 470
Postby JT540 » Fri Oct 13, 2017 12:18 pm
Yes where the starter shaft goes into the housing you have to put a solid plug there. There is an oil galley behind the bearing.
barhopper
Re: Cont 470
Postby barhopper » Fri Oct 13, 2017 9:33 pm
Just plug the hole in the slot where the bendix on the starter goes or something deeper in? If I put the old starter back on would that do it?
Re: Cont 470
Postby John Fenner » Sun Oct 15, 2017 7:27 am
Measure the stub shaft diameter and length to mounting face, slide a piece of same size pipe into it, long enough that the cover plate holds it in place. If no size pipe available, take solid aluminum dowel and have it machined.
Users browsing this forum: No registered users and 10 guests
