Lean/rich settings for 180Lycoming
Marshn
Post by Marshn »
Hey guys,
I'm running a Lycoming 0360 with an MA 4-5 carb. What should I run the lean/rich lever at? Ive been told to run it full rich to keep the engine cool but also to lean it out to save fuel. Any comments are apreciated. Thanks, Ed
SLIDEJOB0520
Re: Lean/rich settings for 180Lycoming
Post by SLIDEJOB0520 »
Personally I would run it full rich without a CHT/EGT gauge to monitor temps.
WHEN IN DOUBT TACH IT OUT!!!!!!!!!
pirate
Post by pirate »
I would run it full rich here in Florida. The lean rich lever for the most part is to lean the engine at altitude where the air is thinner in order to keep the air/fuel ratio at roughly 14.7 to one. Usually when I shut down I go to full lean and when the engine starts to sputter I kill the mags.
Marshn
Post by Marshn »
Thanks much. Will do. :old_glory: :florida: :rebel:
GMAC 76
Post by GMAC 76 »
these guys are right on....run it at full rich and use it to kill the engine at full lean.....if you lean it out while cruising and all of a sudden need to stab the throttle it will usually stall out and fall flat on her face and that is not a good on an airboat!!!!!
