0540 newb
Chicken Man
0540 newb
Post by Chicken Man »
Hey guys. I recently got an 0540 sv,rigging,cage,gas tank,basically everything but the prop and hull at a county auction in north florida. Got it to the shop, messed around with it a little bit and got it to crank. Put a prop on it and cage tied it down to the trailer it is on. Cranked it again let it run at idle for about 5 minutes, not a lot of smoke, mostly from lubricant in cylinders. Checked compression any where from 110-160, number 3 cylinder cold. Maybe mags? Know nothing abut them. Mag numbers S6LN-23 and -21. Any help appreciated.
Re: 0540 newb
Post by John Fenner »
Clean or change plugs first.
Chicken Man
Re: 0540 newb
Cleaned and checked plugs,prior. Pulled plugs on 3 cylinder, after run, both fuel soaked.
Re: 0540 newb
Remove the plug wire harness caps from mags and check for corrosion and or carbon tracing at insulators or from distributor block to case.
Chicken Man
Re: 0540 newb
Pulled the plug wire harness cap off both mags ,right looked alright , I guess. Left mag had one insulator behind cap that is burned,looks like. The 2 mags had different type insulators,left had individual lead insulators, right had one piece isulator for all leads. Checked all plug wires with ohmmeter, looks like one wire bad. Thinking ,maybe, send the mags off to be rebuilt. The hourmeter on motor shows just over 2000 hours. Looks like it has set out for a few years.
GMAC 76
Re: 0540 newb
Post by GMAC 76 »
message sent
Re: 0540 newb
Good call, might just need a teardown, cleaning, blast the distributor blocks and check for cracks, and reassembly.
