0470-13 help
dimotta
0470-13 help
Postby dimotta » Tue Jan 16, 2018 8:36 am
I have a new me 0470-13 and it has a ma-6-aa carb I've been told that the carb is too large but what I want to ask about is after a short ride the engine will smoke blueish grey on one bank of cylinders then it will clear up and start smoking on the other bank of cylinders then it will clear up . After the smoke stops if you rev it up you will get heavy grey/black smoke then clears up any help would be great
dimotta
Re: 0470-13 help
Postby dimotta » Tue Jan 16, 2018 8:41 am
For got to mention it holds 60psi oil pressure idle and at 140 oil temp dry sump oil system thanks
Re: 0470-13 help
Postby Deano » Tue Jan 16, 2018 9:29 am
Not only does your description imply 'them' to be correct, but . . .
Every indication here is that you correct. That is the wrong carb and is to big.
Additionally, you will find a manual for your 'new to you' engine at this link:
http://www.southernairboat.com/pdf/aircraftengines/continental/470/Continental_0-470_13A_IPC.pdf
After you open it, you can [Save As...] to keep a local copy.
GMAC 76
Re: 0470-13 help
Postby GMAC 76 » Tue Jan 16, 2018 7:17 pm
deno is absouletly correct...the 6AA HELICOPTER IS A 277 bore for the 540 engines...you need an MA-4-5 with the 187 bore or a 5AA helicopter carb for your 470...I have afresh rebuilt bench tested 5AA converted to a 4-5 for the 470 if ya wanna do some dealing for the 6AA
dimotta
Re: 0470-13 help
Postby dimotta » Tue Jan 16, 2018 8:54 pm
What you have in mind
Re: 0470-13 help
Postby One Eyed Gator » Wed Jan 17, 2018 10:08 am
Get with GMAC 76 he wont steer you wrong.
GMAC 76
Re: 0470-13 help
Postby GMAC 76 » Wed Jan 17, 2018 12:08 pm
dimotta wrote:What you have in mind
message sent
Alvinlee1915
Re: 0470-13 help
Postby Alvinlee1915 » Thu Jan 18, 2018 7:09 pm
From my experience the grey black smoke would indicate either getting to much fuel or the fuel pressure is off. I don't know if this applies to aircraft engines but the blueish grey smoke would indicate burning oil.
malone
Re: 0470-13 help
Postby malone » Wed Feb 14, 2018 10:11 pm
Pull oil fill cap off, if it smells like gasoline you running rich. If your Oil becomes diluted with gasoline it will cook every metal to metal part in that motor.
dimotta
Re: 0470-13 help
Postby dimotta » Fri Feb 23, 2018 4:55 pm
ok so I took out the boat to the freedom ride ran great except the oil temp was reading 270-280 when crusing around the lake. I changed the oil and cleaned oil screen ect, has 60lb oil pressure idle and running I'm going to change the gauge what do you guys think thanks for any advice
Re: 0470-13 help
Postby kwanjangnihm » Fri Feb 23, 2018 5:13 pm
verify gauge - use a temp gun and check the inlet/outlet of your oil cooler
Re: 0470-13 help
Postby Slidin Gator » Fri Feb 23, 2018 6:17 pm
kwanjangnihm wrote:verify gauge - use a temp gun and check the inlet/outlet of your oil cooler
X2 and check your cylinder temps at the exhaust valve with the same gun too, all idling hot. Any anomalies?
You did not mention anything about the crankcase vent tube, what's going on there? Is it blowing or smoking significantly?
Users browsing this forum: kwanjangnihm and 17 guests
