Very hot cly
Very hot cly
Did a leak down on number 4 cylinder seems to be blowing out the exhaust valve it was almost glowing red the last time I had it outSouthern Airboat mobile app powered by Tapatalk
Sent from my [device_name] using Re: Very hot cly
The jug will be ruined if the valve isn't fixed. I would try to get a look at the valve seat before pulling the jug but even with a good borescope it can be difficult to spot what is causing the problem. A valve can be lapped without pulling the jug but if the seat is actually bad or the valve burned then the cylinder must come off for repair.
