Actual power of a converted GPU to a 470
riverrat1
Post by riverrat1 » Thu Feb 22, 2018 5:43 pm
What would be the actual power of a converted GPU before 70 with 8.6 compression
riverrat1
Re: Actual power of a converted GPU to a 470
Post by riverrat1 » Thu Feb 22, 2018 5:46 pm
riverrat1 wrote:What would be the actual power of a converted GPU before 70 with 8.6 compression
Talk-to-text is terrible
Post by John Fenner » Fri Feb 23, 2018 9:45 am
You are looking at about 240- 260 range.
luv2airboatnhunt
Post by luv2airboatnhunt » Fri Feb 23, 2018 8:12 pm
I agree with John. I've been running a 470 conversion for 10 years with the 260hp dome top pistons. I go anywhere my buddy go's with his stock SV 540 (260hp).
:proud:
riverrat1
Post by riverrat1 » Sat Feb 24, 2018 9:35 am
Thanks
riverrat1
Post by riverrat1 » Sun Feb 25, 2018 5:28 pm
luv2airboatnhunt wrote:I agree with John. I've been running a 470 conversion for 10 years with the 260hp dome top pistons. I go anywhere my buddy go's with his stock SV 540 (260hp).
You are using the the 8.6.1 that comes in the 470 because that's what I have
