0360 id
407_byrd
0360 id
Post by 407_byrd »
picked up this bear 11' 180 boat a couple weeks ago no data tag on engine has a ma 4-5 carb 10-3479 serial number. case is 72133d the measurements from case to end of cylinder is 10 3/4" should b a 0360 has a new 66x38 florida air prop turns it right at 2900 tach bounces around a bit runs great owned by the same owner since 1996 hull is in near perfect shape good bottom with poly no leaks he has run 93 auto fuel since he has owned its a narrow deck engine so assuming its a low compression engine no CHT gauge and the oil temp is not working with a infrared heat gun the hottest cylinder got up to 310f with a short ground run 250f cruising oil sump was at 150f with gun gun 70psi oil pressure crusing around 50psi at a 750rpm idle all on 93 pump gas with octane booster and a little marvel mystery oil. first a/c engine ive owned what should i look for on this engine
what is behind this brass nut?
GMAC 76
Re: 0360 id
Post by GMAC 76 »
the carb is off a 6 cyl 210 franklin engine......should be an oil screen behind the nut I believe...never seen a sump screen on a 360 like that but there are a lot of different engine models....also don't seem like much prop for a 360 ....sweet little boat !!!
407_byrd
Re: 0360 id
Post by 407_byrd »
I think the old man who owned this boat for so long may have had the timing retarded to run 93 pump gas if so how can I check the timing?
GMAC 76
Re: 0360 id
Post by GMAC 76 »
the easiest and most accurate way to find what the timing is set at in degrees btdc would be with an aircraft timing wheel and magneto timing/syncro light...I know there are a lot of different ways to figure out ABOUT where the timing is but this is what I use....if and only if your flywheel is installed properly you can use those timing marks on the fly wheel and the light
407_byrd
Re: 0360 id
Post by 407_byrd »
pulled the big nut off bottom of sump its the oil pump suction screen it was just clean engine oil. pulled the oil filter screen between the mags and found some small black particles look like carbon deposits and also some small metals flakes. should i be worried about the metal, not sure when the last time the oil filter screen was pulled and cleaned the tach shows 1154 hrs i have ran 4hrs runs great. going to fill with fresh oil then run how many hours should i run the engine before i pull the screen again to check? thanks
GMAC 76
Re: 0360 id
Post by GMAC 76 »
I change my oil and add lucas oil stabilizer every 15-20 hrs and check and clean the oil screen cause after all that is the oil filter on your engine unless a remote filter has been installed....if it was me and I didn't know when the last time the screen was cleaned and it did have some sparkle in it I would change the oil clean the screen and run the engine for a few hours and check the screen for any additional metal...that would help tell ya if the orginal metal was along time coming or if something was going on inside the engine right now and give ya a good starting point for future maintiance
