seal behind flywheel came out
swump_man
Post by swump_man » Thu Mar 15, 2018 8:52 am
can you change the seal behind the flywheel on a 4 cyl 160 lycoming without breaking the block into?? help!!
No stick'n---Just slidin'
GMAC 76
Re: seal behind flywheel came out
Post by GMAC 76 » Thu Mar 15, 2018 10:33 am
yes....they have a new style seal now with magic fingers embedded in the seal so ya don't have to fight that damn little tension spring...I put one in my 200 9 yrs ago and still dry
swump_man
Post by swump_man » Thu Mar 15, 2018 2:45 pm
Where did you get it from
GMAC 76
Post by GMAC 76 » Fri Mar 16, 2018 9:35 pm
I picked mine up at preferred airparts...aircraft spruce has them also...but I bet any good engine builder here in fla has them....the part number is I think is LW11997 CRANKSHAFT OIL SEAL with impregnated spring but double check....they are not cheap but worth every penny...I believe mine was about $75 9 yrs ago so might be close to a $100 by now
Gary S
Post by Gary S » Sat Mar 17, 2018 7:48 am
Was it solid or split?
swump_man
Post by swump_man » Sat Mar 17, 2018 8:47 am
I have not pulled the flywheel off yet to look. I can feel it dangling. I think it is solid. The spring part fell in my hand
GMAC 76
Post by GMAC 76 » Sat Mar 17, 2018 10:15 am
the old one was solid...had to have a special tool and heat to install it....this one was split
swump_man
Post by swump_man » Tue Mar 20, 2018 5:40 pm
Ok guys. I pulled apart today and it was a split seal with the spring. It did not look messed up so I put it back in and put the spring together and back in. However the seal went inn fairly easy. Is this normal???? Gmac 76??
boatair
Site Supporter - VII
Post by boatair » Tue Mar 20, 2018 6:08 pm
If it won't stay I would get a solid unsplit seal , remove the spring, boil the seal in water, stretch it over the crank flange, put the spring back in and glue the seal to the case with weather strip adhesive . Make sure you let the adhesive cure completely .
GMAC 76
Post by GMAC 76 » Tue Mar 20, 2018 7:24 pm
swump_man wrote:Ok guys. I pulled apart today and it was a split seal with the spring. It did not look messed up so I put it back in and put the spring together and back in. However the seal went inn fairly easy. Is this normal???? Gmac 76??
what type of ahdhesive did ya use around the out side of the seal.....it is very important that the seal and the engine case be clean and dry and a high grade adhesive be used and the split be put at the proper position...some of them like mine actually have a 2 piece steel plate that bolts on to the case and helps hold the seal in place
swump_man
Post by swump_man » Wed Mar 21, 2018 7:30 am
That was a concern. It did not look like it had any adhesive on it before so I did not use any. I did put the split on the top. I don't see any sign of it having a plate that bolts on to help hold it inn place but I'm going to look again to see if that is a possibility. I have a 3m adhesive that I can use also.
Gary S
Post by Gary S » Wed Mar 21, 2018 8:03 am
Permatex 25229 The Right Stuff 1 Minute Gasket Maker. Use this.
GMAC 76
Post by GMAC 76 » Wed Mar 21, 2018 11:56 am
swump_man wrote:That was a concern. It did not look like it had any adhesive on it before so I did not use any. I did put the split on the top. I don't see any sign of it having a plate that bolts on to help hold it inn place but I'm going to look again to see if that is a possibility. I have a 3m adhesive that I can use also.
I use hi tack on the seal and the ends of the seal split also offset the split from the case split I belive the manual says 11 or 1 oclock depending on the crankshaft rotation
