520 model ID
Keeth1123
520 model ID
Postby Keeth1123 » Tue Apr 03, 2018 6:51 pm
Where is the plate that designates what variant the motor is. It is fuel injected, this much I know.
Looking to see horsepower range for it
:old_glory:
GMAC 76
Re: 520 model ID
Postby GMAC 76 » Tue Apr 03, 2018 7:08 pm
cont plates are usually found in the middle on the top side of the engine case.....fyi all 520's were fuel injected
Keeth1123
Re: 520 model ID
Postby Keeth1123 » Tue Apr 03, 2018 7:32 pm
If the plate is missing is there any way to tell. Internate claims these motors are close to 300 hp
:old_glory:
malone
Re: 520 model ID
Postby malone » Tue Apr 03, 2018 9:47 pm
https://en.m.wikipedia.org/wiki/List_of ... ft_engines
This is the most comprehensive list of aircraft engines I have found. I have an O 520
But it is a O470 gpu build with Gitsu jugs. The numbers were attached to the case with aluminum tag from the factory mine are long gone as are most.
Happy hunting
GMAC 76
Re: 520 model ID
Postby GMAC 76 » Wed Apr 04, 2018 10:15 am
my papers show the io-520 a,b,d,f,j,k,l,m engines are rated at 285-300hp.......the tiso and gtiso engines are rated at 285-375 hp
Keeth1123
Re: 520 model ID
Postby Keeth1123 » Thu Apr 05, 2018 10:23 am
How would one of these motors perform on a 12’6 x 7 diamondback hull
:old_glory:
GMAC 76
Re: 520 model ID
Postby GMAC 76 » Thu Apr 05, 2018 12:27 pm
imo....with that kind of true hp on that hull with the right prop you would be very happy....especially if the rigging and all metal work were done right
Keeth1123
Re: 520 model ID
Postby Keeth1123 » Thu Apr 05, 2018 2:12 pm
Rigging is rear driver (2 single seats) and a double seat up front. I have never had a rear drive boat before.
:old_glory:
GMAC 76
Re: 520 model ID
Postby GMAC 76 » Thu Apr 05, 2018 3:16 pm
imo it is alot of weight....alot of passengers for a 12' hull for real performance but hey it might do want ya want...ya got a lot of power....I had a buddy who had the same hull and setup with a 540 and it did ok.....he changed it to a single driver rear and a single passenger ...he said it was like having a totally different boat the way it preformed on the hill and in the water but his 540 was the 250hp so like I said ya got some power to work with
Keeth1123
Re: 520 model ID
Postby Keeth1123 » Thu Apr 05, 2018 4:43 pm
Anyway to tell if it’s the 250hp model of the plate is missing? I don’t plan on running 4, but it was that package. I was hoping for a single front driver, double rear. I’m looking for ride/hunt boat for two
Also, I thought these motors had to be leaned out to turn off but I didn’t see a lean/rich lever on the boat
:old_glory:
GMAC 76
Re: 520 model ID
Postby GMAC 76 » Thu Apr 05, 2018 8:09 pm
how could it be a true io-520 and have only 250hp when the book on them shows 285 to 300hp ....my friends engine was a 250hp but it is a carbureted 540 Lycoming totally different animal... there is an engine kill lever on the io's on the servo....
Users browsing this forum: No registered users and 40 guests
