O320 accessory housing plugs
krazymatt
Post by krazymatt »
Motor is o-320. Anyone know the part numbers or where to get the plug to plug hole just above the oil screen housing?
Also looking for the plug that goes in bottom of housing to plug the oil passage way when using pickup tube. Or you guy just leave it open and let the gasket seal it? Parts list shows a plug says it's 5/8"
Thanks.
Seadrift
Re: O320 accessory housing plugs
Post by Seadrift »
I tap them to use pipe threads when ever I can
2000 Combee 18' / TIO 541 Don't laff, it takes me there and brings me back.
Post by John Fenner »
If you are plugging the oil cooler bypass galley, does your screen housing have a vernatherm in it? If not you need the plunger, spring, and the #6an plug for it.
Does that front cover have the provision to run a pickup tube? If so the gasket will suffice in sealing the pickup galley with the solid sump boss, pickup tube shall go into a screen in bottom of sump.
flyontario@gmail.com
Continental C85
Post by flyontario@gmail.com »
I am in need of an alternator to replace the generator on a c85.
D you have one of these?
John Watson
krazymatt
Post by krazymatt »
John Fenner wrote:If you are plugging the oil cooler bypass galley, does your screen housing have a vernatherm in it? If not you need the plunger, spring, and the #6an plug for it.
Yes i got a vernatherm valve for the oil screen housing. Trying to plug the hole on top of the oil filter housing pad. Looks like a str8 thread with plug that seals with copper washer? The housing does have provisions for oil pickup and I do have the screen for the end down in the sump.
Should be #6 an
