Push Rod Tubes for Lycoming O-320 AV (170)
JCGator
Post by JCGator » Mon Feb 04, 2019 8:33 am
I have an o-320 with AV 480 cylinders on it and looking for a PN for the push rod tubes used on these. I figured they are the same as a 480 but dont want to order the wrong thing. thanks
10'6" Taylor Hull. Lycoming 170 hp - O-320 w/ 480 AV jugs
twister69z
Re: Push Rod Tubes for Lycoming O-320 AV (170)
Post by twister69z » Tue Feb 05, 2019 9:38 am
they are the same as GO-480
