looking at a Igso480
smokster
Post by smokster »
im looking at a boat with an Igso480 and was wondering why you dont see many of these motors and if parts are hard to come by. i would love some opinions on how they hold up and some pros and cons. this motor has 126 hours and built by wally more. thanks in advance
Blownaway540
Re: looking at a Igso480
Post by Blownaway540 »
I have a IGSO minus the gear drive, they suck some fuel but are a tractor. Never, I mean never have to get off and push and pull. I got to old and lazy for that. Take care of the engine, don't let the CHT get to hot and they will last you. You get back on green/dry and run for miles you will burn it down. Mark
IGSO 0540 (W/out IG) built by the late, great, Dick Hoffman, 13 ft. Alumitech. Member - CRA, KRVSA
SuprchgedPalmBeach
Post by SuprchgedPalmBeach »
The power is uncomparable..it does require a cooling shroud with correct design, meaning not the ones that are 2" above the cylinders with the cute louvers. Letting the cylinders get hot will end this motor. The shroud goes with prop sizing to pull ample amounts of air through the cylinders, i run a 82" 3-blade JX with a shroud with 11" spacing at rear. Also if you run it lean will also run the cylinders hot, i run a holley AED 850 with (2) carter 4600 fuel pumps (1) pump per side of carb (double pumper), pulling through a Racor S3232. Solid, powerful motors but setup is critical.
smokster
Post by smokster »
SuprchgedPalmBeach wrote:The power is uncomparable..it does require a cooling shroud with correct design, meaning not the ones that are 2" above the cylinders with the cute louvers. Letting the cylinders get hot will end this motor. The shroud goes with prop sizing to pull ample amounts of air through the cylinders, i run a 82" 3-blade JX with a shroud with 11" spacing at rear. Also if you run it lean will also run the cylinders hot, i run a holley AED 850 with (2) carter 4600 fuel pumps (1) pump per side of carb (double pumper), pulling through a Racor S3232. Solid, powerful motors but setup is critical.
thats some great information, i sure would like to see a picture of your shroud. thanks
SuprchgedPalmBeach
Sent you a PM
nunook
Post by nunook »
Gary Barber@outlaw has the parts for the GSO480. I have a GSO 480 I agree they are a work horse, with the right prop and gear reduction mine is pretty good on fuel as long as I'm just cruising. If I lay into it with the twin Aircraft Carbs it will drink the fuel
2006 Floral City 14' Deckover Lycoming GSO-480
