Perplexed by Mag ID
DHam
Perplexed by Mag ID
Post by DHam » Tue Apr 09, 2019 10:33 pm
Have 0-320 with a mag drop issue. GMAC gave me some input on a previous thread and I Have searched the forum and have a list of leads to go through. This all prompted me to read the bendix manual. So here comes my question. My id plates show my impulse mag is S4LN-21 and my other Mag is S6LN-23. Manual says the 6 designation is for 6cyl??? Is it as simple as somebody used a S6 case and filled it with parts to run a 4cyl? Thanks for your thoughts.
Resurrecting 11x7 3/4 deck sled. slick bottom. 0-320 160. 66"WW. :stirpot: :violent1:
Gary S
Re: Perplexed by Mag ID
Post by Gary S » Wed Apr 10, 2019 6:44 am
yep
GMAC 76
Post by GMAC 76 » Wed Apr 10, 2019 10:24 am
welcome to the world of Frankenstein mags and carbs.....all the cases in the 20/200 series are basically the same ...the tags are from factory assembly......the s6ln-23 mag is oem on the 220 gpu but can easily be converted to a 4cyl mag by changing internal parts and the setup....so to answer your question yes it is that simple
AirHog
Post by AirHog » Wed Apr 10, 2019 4:15 pm
You can’t be using big words like perplexed..... most members probably thought you were talking about a gasket compound.....
Snicker
AirHog
southern safaris
Post by southern safaris » Wed Apr 10, 2019 8:46 pm
AirHog wrote:You can’t be using big words like perplexed..... most members probably thought you were talking about a gasket compound.....
Snicker
AirHog
I literally just choked on my dang beer when i read that lol now that s%$! Was funny!!! :drunken: :slap:
Anthony Hughes
Madison FL
850-973-2642
580-228-5782 cell
Aluminum round-sided hulls
DHam
Post by DHam » Wed Apr 10, 2019 11:24 pm
Snicker
AirHog
:lol: :cheers: I guarantee these boys know a helluva lot more than I. Really appreciate all the Info and knowledge you guys share. Funny thing is my dad bought this boat in’83. I ran it in the ground my whole life. 36 years later I’m finally learning something about how to keep it together. Thank you all.
