Proper oil level 0360
BlowinBills
Post by BlowinBills » Wed May 01, 2019 3:05 pm
I have an all stock 0360 180hp straight valve narrow deck and wanna know how much oil i should be running in it, the cap says 6qt, the boat has the big 6 row Hayden oil cooler on it too. 6 qt doesn’t fill it up on the stick but maybe 2/3 the way up.
twister69z
Re: Proper oil level 0360
Post by twister69z » Wed May 01, 2019 4:10 pm
Stock it should have 8 qts without the cooler. Most run 7 .
