Need help figurung out what egine I have
Stroker8
Post by Stroker8 » Thu Aug 15, 2019 7:45 pm
:old_glory: :florida: :rebel: :scratch:
Hello everyone,
I am a new Florida resident, a first time airboat owner and new to the Southern Airboating community. I am an automotive V8 guy, I play with car and trucks, I never touched an aircraft engine before, I never drove an airboat before and I'm not going to drive this one until I do my research first. I actually acquired this airboat on a trade for a older peace of construction equipment I had. The person who traded it to me got the boat as a form of payment for a big job he did and knew nothing about it other then how to start it. So I have an airboat I know nothing about other then how to start it and that it is a continental 6 cylinder with an engine block casting date of 5-15-61. I did a lot of google searching trying to figure this out, that is how I found Southern Airboating. I hope someone here could give me some pointers on how to figure out what engine this is. Here are some pictures
THANK YOU
Dirtman
Re: Need help figurung out what egine I have
Post by Dirtman » Thu Aug 15, 2019 9:32 pm
From the limited experience that I have with Continentals it appears to be an 0-470 Not sure of the HP but would guess in the 230 to 250 range.
Stroker8
Post by Stroker8 » Thu Aug 15, 2019 10:12 pm
Thank you Dirtman. Limited experience or not, any input is greatly appreciated.
Gary S
Post by Gary S » Fri Aug 16, 2019 6:44 am
Well now you've done it,your going to be hooked. Looks like a IO470. Good strong dependable engine. Does it run? Whats the rest of the boat look like? Hopefully you get with someone that can get you up to speed on the do and don'ts and take you somewhere shallow to start having some fun.
Post by One Eyed Gator » Fri Aug 16, 2019 7:21 am
Under the aircraft section of this forum there are 0470 manuals.
Be sure you understand how the mags work before you mess the the prop by hand.
Stroker8
Post by Stroker8 » Fri Aug 16, 2019 9:30 am
Thank you for the response Gary S. Yes the engine fires right up and runs smooth, it is running on AV fuel, so I know that much. The boat itself is in nice shape, according to the title, it is a 2006 model. I'm not sure of the make, but it is a 12' 3" fiberglass hull, with the what looks to be a barely used polymer sheet on the bottom. When I take the cover back off the boat I will take some more pictures and post them for you. Like I said in my initial post, never owned an airboat, I know nothing about them, I was taking a chance with this trade deal. What made me go through with the trade was the fact that the boat was in real nice shape, it looked like an aircraft engine, it started right up ran nice, it came with a trailer and the main fact was I just think airboats are awesome. So all the information and pointers I could get on this forum from experienced airboaters such as yourself are greatly appreciated.
Stroker8
Post by Stroker8 » Fri Aug 16, 2019 9:31 am
Thank you One Eyed Gator, I will check out the manuals
flcracker9
Post by flcracker9 » Fri Aug 16, 2019 11:21 am
They usually have a data plate mounted to the case in front of the right side mag (left side if you are standing behind the boat looking at the prop), if the data plate is still there, it will tell you what model and what HP at what RPM?
Stroker8
Post by Stroker8 » Fri Aug 16, 2019 1:39 pm
Hello Flcracker9, I did find what looks to be a data tag in the location you described and this is what it looks like.
Stroker8
Post by Stroker8 » Fri Aug 16, 2019 8:29 pm
Here you go Gary S. You asked how the rest of the boat looks, well this is it.
Gary S
Post by Gary S » Sat Aug 17, 2019 6:19 am
Nice. Go easy with it and don't be in a hurry to take friends and family with you. Find someplace shallow and get the hang of it. Just remember, you can't turn without power, always have some in reserve for the unexpected. You also have to be aware where your prop blast is going. When you take off make sure your not going to blow someone around behind you.
Post by John Fenner » Sat Aug 17, 2019 7:13 am
Solid advice from a true gladesman, Gary is spot on as usual!
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 9:16 am
Thank you Gary for the advice. I was reading some other conversations of new airboaters and the advice they were given. One of the things that stuck in my head was “when in doubt throttle out” and don’t lift off the throttle fast from higher speed, the wake could come up and over the back and sink you.
I think I am going to try meeting up with someone who is experienced with an airboat that wouldn’t mind taking me out for a ride on their boat and give me a little training. I probably should have that same person look over my boat to make sure it’s safe to take out. I’m not even sure where to go that has shallow areas to practice. I am in Yeehaw Junction near the sr60 and 441 intersection. I have blue cypress to the east of me towards vero, the west gate river ranch to the west of me and okeechobee to the south. I know there is a boat launch on sr512 for blue cypress, I believe they do the big family airboat rides there. I have even seen people launch anywhere alongside 512. So anyone have any suggestions?
Post by kwanjangnihm » Sat Aug 17, 2019 11:35 am
Welcome to SA Stroker8!
Here is a link with some great info for new airboaters: viewtopic.php?t=30116
Get some seat time and slide safe bro! :thumbleft:
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 12:03 pm
Thank you for the "Welcome" kwanjangnihm and the link. I have to say, so far I am glad I joined SA, everyone has been friendly and helpful.
Scotty1
Location: ft white fla and former Naples fla cracker for 48 years
Post by Scotty1 » Sat Aug 17, 2019 2:51 pm
:rebel: Looks like the boat has pretty good chimes on it so that is a plus ,so it should turn good and not slide as much. your best bet would be to find a big open field with shallow water to mess around in it till you get a little more comfortable with it . just remember safety always first and welcome to the addiction of airboating. :rebel:
CypressHunter
Post by CypressHunter » Sat Aug 17, 2019 3:41 pm
Stroker8 wrote:Thank you Gary for the advice. I was reading some other conversations of new airboaters and the advice they were given. One of the things that stuck in my head was “when in doubt throttle out” and don’t lift off the throttle fast from higher speed, the wake could come up and over the back and sink you.
I am in Melbourne and never put in down near Vero but on the east side of 512 “East Marsh” as it’s called is probably not a bad spot. But go with someone know knows it’s. If you got a buddy with a flooded pasture that’s another option.
Only thing I can think to add is when running trails keep your eye out for other boats coming in the distance. Birds getting up is a good give away and when coming head on with another boat always go right.
If I had some time, new baby at home, I know some areas up here that are good for a beginner
Good luck and enjoy
Striker543
Post by Striker543 » Sat Aug 17, 2019 8:49 pm
You can also go to lake cypress. Take 441 north and turn left on canoe creek, then head north till you get to the lake cypress road. It’s about 45-60 minutes from yeehaw.
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 9:23 pm
I’d like to thank kwanjangnihm again for that link, it was very helpful, a lot of good info. After reading that, I am going to go over every nut and bolt. I found the sticker on the prop listing the torque specs and that it should be torqued every 50 hours, so I’m going to check that since I don’t know when it was done last. Then I will give it a fresh oil change and filter, maybe a fresh set of plugs. Definitely going to go over this boat top to bottom before it hits water. Like many of you have said, “safety first”!!
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 9:26 pm
Thank you for the “welcome” Scotty1 and the advice.
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 9:29 pm
Thank you Cypresshunter for the advice and location, I will have to check it out.
Stroker8
Post by Stroker8 » Sat Aug 17, 2019 9:31 pm
Thanks for the location striker543, I will have to check it out when the boats ready, or I should say when I am ready, lol...
Post by John Fenner » Sun Aug 18, 2019 8:53 am
When in doubt throttle out is great, always have reserve thrust when needed, learn the boat's characteristics, where it planes out, ride or cruise there or slightly above plane, feel it out in a prairie, find out how it responds to rudder control, set up a slollam course that you can maneuver without throttle blips, then at end of slollam pull a full and hard u turn and go back through the slollam course, being able to avoid a collision is key, you want to be able to stop that boat in its tracks by a quick rudder pull and a full throttle spin up to avoid an accident even in the tightest trail or even deep water situation to where you don't swamp the boat or sink it.
Stroker8
Post by Stroker8 » Sun Aug 18, 2019 9:21 am
Thank you John, I appreciate all the advice. I’m a car guy, so I know slalom courses. I just never tried a slalom with a boat, let alone an airboat. But it sounds like a great way to learn the boat.
Stroker8
I have to say, I am glad I joined SA before Doing anything with this boat. Everyone has been very helpful, thanks everyone!!!
