Scotty,
The numbers are of no value, the engine has been modified from it's original build. For starters, all angle valve engines were fuel injected from the factory. To install the updraft carburetor, a previous owner replaced the oil pan with one from a straight valve. They also would have gutted various accessories that might have been used on a plane. We know it's an angle valve 360, wide deck with a 6AA carb (that may or may not have been modified). The one thing you don't know is what compression pistons are in the engine (7.5, 8.5 or 10:1). A compression test might give you a clue, but you would have to pull a jug and measure the piston or get the numbers to know for sure.
I run Autolite 373 plugs, there are lot's of options and even more opinions, just search this site for plug info. I run these plugs because the are in stock at the local AutoZone for cheap and at the low end of the heat range. The heat range being the primary criteria and I would suggest that these are good plugs for you to start with. If you find that the plugs are fouling, particularly if you do a lot of low speed running, froggin etc., then you might want to go up on the heat range (Autolite 376 etc.) to help burn off the deposits, just keep GMAC's advise on carb sizing in mind.
The Champion D16 and UD16 are a similar heat range to the 376, the UD16 adds an auxiliary gap that helps with fouling if it's a problem. Read more on this subject at the following link.
https://www.yesterdaystractors.com/cgi- ... &th=345062
You should also use copper gaskets in place of the steel gaskets on any of these plugs. I cut off the factory gaskets, the copper really helps keep the plugs cooler, which keeps cylinder temps down (same reason I run colder plugs).
https://www.aircraftspruce.com/catalog/ ... skets2.php
