No spark on Bendix mags
Wllmclrk3
Post by Wllmclrk3 »
Lycoming 0290. Just installed Bendix mags that use an external coil. Just a 12v universal ignition coil. Not getting any spark from the coil. Bought two new coils and filed the points. Still no spark. Mags came off a running engine a few months ago
Re: No spark on Bendix mags
Post by Slidin Gator »
Not many of us running them dinosaurs. You should be able to spin them on the bench and get spark, check your wiring inside, it sounds like something that is grounded that shouldn't be, or something is not connected that should be.
