501 cubic inch LS motor
Waterthunder
Postby Waterthunder » Wed Sep 17, 2008 7:01 pm
This is gonna be fun. I'm building a 501 cubic inch LS motor for somebody outside of the US. I will post some of the build pic's the boat builder may also pay me to dyno tune the motor if so I will post the numbers. Were shoting for 700/700!
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
RIDINFILTHY
Re: 501 cubic inch LS motor
Postby RIDINFILTHY » Wed Sep 17, 2008 8:31 pm
that is awesome!!!!!!!!! keep us up to date please
12 ft. sbc dd boat. its real bad a$$
FELBER632
Postby FELBER632 » Wed Sep 17, 2008 11:33 pm
NA?
Waterthunder
Postby Waterthunder » Thu Sep 18, 2008 8:20 am
Yes Felber the first one will be NA. I believe they will get one NA motor and then one blower motor. They both will be fuel injected and that is what they are realy after. I know they will buy one or two then start building their motors their selves! There is no doubt they are going to start building their own boats and motors. I now believe the most valuable thing I have learned from AEW is how to charge the copy watch makers.
321-508-5316
Norris
Postby Norris » Thu Sep 18, 2008 10:50 am
Dave thats cool, Im building the same thing for my new boat, but going to go a little smaller, 481.
Keep us posted. We should be getting started in a week or so..
Atlas
Postby Atlas » Thu Sep 18, 2008 2:19 pm
LSX block?
Olf Art
Postby Olf Art » Thu Sep 18, 2008 2:25 pm
Yup, it sounds like they want to buy your fuel injection programming, Dave.
Back-engineering at it's finest. :roll:
Norris
Postby Norris » Thu Sep 18, 2008 2:28 pm
Mine will be a world products block.
Waterthunder
Postby Waterthunder » Sat Sep 20, 2008 11:18 pm
Olf Art it doesn't matter there are just as many copy cat's here accept the ones here will slit your throat from the back at least with foreigners you know what’s gonna happen up front!
321-508-5316
Norris
Postby Norris » Mon Sep 22, 2008 8:28 pm
Dave, what are using for a block on this motor?
shiggs
Postby shiggs » Mon Sep 22, 2008 9:24 pm
Dave,
We gotta have a report on how this one comes out.
Anxiously waiting!!! :twisted:
sh
Waterthunder
Postby Waterthunder » Mon Sep 22, 2008 10:25 pm
Rotating assem came in today! It's gonna take a bunch of work to make everything clear! I will post some pi'c once I start on it. I gotta finish 3 430's first then I can start on the Big One!
321-508-5316
airduds
Postby airduds » Thu Mar 19, 2009 9:28 am
Update?
Waterthunder
Postby Waterthunder » Thu Mar 19, 2009 10:58 am
She is a beast and is on a 18ft survey boat. They put over a hundred hours on it in one month. The owner say’s they haven’t been able to get her stuck yet! She run’s like a Champ swinging a 4 blade!
321-508-5316
crowhater
Postby crowhater » Thu Mar 19, 2009 11:24 am
Waterthunder wrote:She is a beast and is on a 18ft survey boat. They put over a hundred hours on it in one month. The owner say’s they haven’t been able to get her stuck yet! She run’s like a Champ swinging a 4 blade!
Just a question?? If they wanted a 501 why not just get a big block?
flying fish
Postby flying fish » Thu Mar 19, 2009 12:29 pm
Money not an object.
501 LS motor. Now thats really something.
When I wear out my 434 23 degree motor, I will own a 430cid FI LS motor.
Sure wish I had found this website a couple years sooner. :)
crowhater
Postby crowhater » Thu Mar 19, 2009 3:10 pm
flying fish wrote:Money not an object.
I understand wanting to do your own thing, heck I could write a book on that, but an outfit like this kind of threw me. I mean why have somthing so exotic, when you could just build a big block for less money?
Waterthunder
Postby Waterthunder » Thu Mar 19, 2009 3:41 pm
I know on the boats I run an 500 inch LS will run better then a big block! Once again it comes down to preferance also these guy's have ran dozens of 572BBC and they like the big LS much better! Also they burn over a tank less of fuel a day with the LS and when you run your boat for profit that's very important. They told me they save over $150 a day on fuel alone! An Aluminum LS vs an aluminum BBC the LS is around $3,500 cheaper just for the block alone!
321-508-5316
Norris
Postby Norris » Thu Mar 19, 2009 6:23 pm
As a guy building a large cube ls engine, (481) i am pretty sure a guy could build a 496 chev or even a 540 quite a bit cheaper,, and have similar performance, including fuel consumption...
Hell my crank cost bout 1500 dollars, and had 6 peices of mallory in it.. bout 1100 dollars more than a bblock... ?What is the price range for a waterthunder 500 cubic inch LS?? 25,000?? 18,000??
Waterthunder
Postby Waterthunder » Thu Mar 19, 2009 8:17 pm
I have learned when you build a custom motor they all cost about the same. Big Block, Small Block, Chevy, Dodge, Ford even OLD's and Caddy!
321-508-5316
crowhater
Postby crowhater » Thu Mar 19, 2009 8:34 pm
Waterthunder wrote:I know on the boats I run an 500 inch LS will run better then a big block! Once again it comes down to preferance also these guy's have ran dozens of 572BBC and they like the big LS much better! Also they burn over a tank less of fuel a day with the LS and when you run your boat for profit that's very important. They told me they save over $150 a day on fuel alone! An Aluminum LS vs an aluminum BBC the LS is around $3,500 cheaper just for the block alone!
Thank you! I was not trying to goof on anyone I wanted to know what the up side was.
JAMES
Postby JAMES » Thu Mar 19, 2009 8:53 pm
is this an airboat motor your building ????????/ fo r the customer
Norris
Postby Norris » Thu Mar 19, 2009 10:54 pm
when you say the ls block is 3500 cheaper are you comparing a production 6 ltr ls, with an aftermarket 8.2 or larger big block??? it seems to me that pound for pound and cubic inch for cubic inch, bb chev and aftermarket LS blocks are similar priced or the LS is more: SO IAM NOT FOLLOWING YOUR NUMBERS????
Waterthunder
Postby Waterthunder » Fri Mar 20, 2009 12:35 am
I'm comparing an aluminum production LS to a aluminum big block! The 500 inch motor was not production block but the other four 430 cubic inch LS motors I built them were based on production LS blocks! I get the blocks for around $3,500 less then I can buy an aluminum big block for! I can buy the after market LS block that is capable of 500 plus inches for about a $1,000 less then a BBC aluminum block!
321-508-5316
lil_armond
Postby lil_armond » Mon Mar 23, 2009 8:47 pm
I don't know who these guys are but every one I know who works their boat gas is not an issue even if you bur 5 tanks a day it is included in the rental rate. If they are not doing that they are getting screwed. Sounds cool, keep us posted.
''Life's tough......it's even tougher if you're stupid.''
-- John Wayne
15' x 8' Alumitech w/ 84" 5 blade Superwide
