1st Time Caddy Build
AirPat
Post by AirPat »
I am finally picking my motor up from the machine shop today after a long wait. I am going to start to assemble the motor tomorrow. I have never built a motor before so I am looking for any pointers you guys have. I have bought about every book there is to buy on this motor and have read countless post on here about the cad motor. Here is a short run down of what I have:
Motor was a 472.
New 500 crank ground and polished.
.30 over
New Potter DD cam and springs
Silvia (sp??) pistons
New valves
Cloyes chain
New edlebrock intake
All machine work done.
Basically the only parts I kept from the original motor was the piston rods and the push rods. I know I am leaving things out. Looking for some pointers if anyone has any. The boat is a 15X8 fiberglass DD.
Ruagatr
Re: 1st Time Caddy Build
Post by Ruagatr »
This is a tough engine for your first build because they are unforgiving on tolerances. IGNORE the factory tolerances for this use. Your crankshaft main bearings need to be at least .001 oer inch of bearing or .00325. The rod side clearances MUST be at least 25 thousands if not 30. Mine are 35 in some of my engines. If the clearances are less, return the engine to the machine shop and get it done right. Your Silvolite pistons should be fine, as will the stock rods. Use the ARP bolts! and you MUST have the rods resized if you use these bolts. Use a FACTORY aluminum oil pump, NOT the mellings pumps--they are junk. Feel free to call me for help as you go--you will thank yourslef for spending two extra weeks doing this right rather than burning it up and starting over...Charles (954) 444-three 189
JAMES
Post by JAMES »
WHAT KINDA BEARINGS DID U BUY??? AND FOR GASKETS SOME OF THE CHEAPER GASKETS TEND TO HAVE WEAK REAR MAINS ALSO I SEE U BOUGHT POTTERS D/D CAM DID U GET THE ACC.CAP FOR THE END OF THE CAM BECAUSE THE STOCK CAP WILL RUB ALL THEM WILL DO THAT FROM THE CAM WALKING A LIL BIT. BUT IF U NEED TO U CAN USE POTTERS (ROLLER CAM BUTTON) IT WILL STOP THE WALKIN WHEN MINE DID IT IT LIKE DUG INTO THE TIMING COVER. AND I TAKE IT YOUR USING THE 493 HEADS 120CC U SAID NEW VALVES DID U BUY THE 1 PIECE SS STOCK SZ OR OE VALVES
GOOD LUCK
fatboy0054
Post by fatboy0054 »
The phone call to Clarles will be the best thing you could do !And will save you more wallett than you will ever know !Just plain fact !Wasnt going to there but i guess i allready did !Dam it ,hate when that happen ! :lol:
(Disclaimer )! Which means ! Dont try to sue me for your own stupidity !
http://www.mymudspace.com/fatboy0054
http://www.myspace.com/fatboy0054
crowhater
Post by crowhater »
Do not drive your crank timming gear with a hammer.
bob500
Post by bob500 »
I have learned that Ruagtr has forgotten more about Caddy motors than most know. He is a wealth of knowledge. If he says it, count on it. He and Bondsman are most generous with accurate information. Having the sense enough to listen can be a challenge for some. Both have been exceptional resources for my build that is almost done.
Bob
Smuggler
Site Supporter - VII
Post by Smuggler »
bob500 wrote:I have learned that Ruagtr has forgotten more about Caddy motors than most know. He is a wealth of knowledge. If he says it, count on it. He and Bondsman are most generous with accurate information. Having the sense enough to listen can be a challenge for some. Both have been exceptional resources for my build that is almost done.
Bob
I 2nd that :D :D :D
AirPat
Post by AirPat »
I appreciate all the info. I was unable to start the build becuase the rod bearings I recieved with the crank are damaged. The company is sending over another set.
James,
The gaskets are Fellpro. I am not sure what you are talking about on the cam. I had the machine shop call Potter for any special instructions and he said I should be fine. The valves are one piece. The heads are 76cc. Rings and bearings are from Federal Mogal ? I bought a kit with all the parts and this is what it said on the box.
Ruagatr,
Thank you for the offer. I am sure I will take you up on it.
Thanks again,
Pat
T-REX
Post by T-REX »
make sure you use a cloyes roller timing chain. PERIOD. :)
not stock replacement!!!!!!!!!!!!!!
AirPat
Post by AirPat »
10-4 on the Cloyes. That is what I have.
