LT-1 info needed
undicided
LT-1 info needed
Post by undicided » Tue Sep 15, 2009 4:16 pm
I bought a LT-1 today dont know much about them but couldnt pass it up. Can yall tell me a little about it. right know it has fuel injection w/ no distributer (geuss its running off coil packs?). So the BIG question is what am I in for would like to use it to build a gear reducted sled :? can I put a HEI distributer on it w/ carb or do I have to run a carb with a coil pack?
crowhater
Re: LT-1 info needed
Post by crowhater » Tue Sep 15, 2009 4:24 pm
Call Waterthunder.
undicided
Post by undicided » Tue Sep 15, 2009 4:27 pm
crowhater wrote:Call Waterthunder.
Im hoping he will chime in
bushhawg
Post by bushhawg » Tue Sep 15, 2009 4:33 pm
I put one on my boat and made it carb and HEI. Itputs out really good power but the waterpump is reverse flow so pay attention to how you run the water lines to the rad. They do have thier problems to deal with but its very doable
WORK HARD PLAY HARDER!!!
undicided
Post by undicided » Tue Sep 15, 2009 4:51 pm
bushhawg wrote:I put one on my boat and made it carb and HEI. Itputs out really good power but the waterpump is reverse flow so pay attention to how you run the water lines to the rad. They do have thier problems to deal with but its very doable
Thats good to here a freind of mine told me that they wernt made to put distributers in so thats a relief
Waterthunder
Post by Waterthunder » Tue Sep 15, 2009 4:53 pm
That is not a good motor that is why GM ditched it so quickly! If you want to use it they have waterpump, distributor and cooling system problems! I would never use one but if you are ditch the stock ignition!
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Bruce
Post by Bruce » Wed Sep 16, 2009 9:03 am
my dad has one on his boat it makes great power it has an hei distributer and carburetor but do watch out for the reverse flow cooling system i believe he ordered the intake from summit racing
12 foot Mamba "The Underdog"
