Engine Weights
cajun_ag
Engine Weights
Postby cajun_ag » Mon May 24, 2010 12:22 pm
I'm looking to find out how much of a weight difference there is between an LS motor and a big block 454 & 502. Also what's the weight defference between and AL & iron big block. I don't know much about engines so if I'm leaving some critical info out let me know. I will be upgrading to an 18x8 airboat bowfishing rig soon and a concern is that when you get 3 ~200# guys on the front of the boat that the rear tries to come out of the water with a small block. This causes it to draft deeper in the front and also makes it very difficult to steer especially in a little wind. There are some that use the big block just for a counter weight ,but it seems to me a ballast tank could be built to offset the weight difference. When you get ready to go just pump it empty and you get the performance back. On a 18x8 barge all this may be a mute point. :lol:
"Red Rocket" 2007 18X8 Air Ranger Rhino Edition, 540 ci chevy
mudkat
Re: Engine Weights
Postby mudkat » Mon May 24, 2010 9:01 pm
we just weighed a 400 small block alum heads,waterpump and intake. no starter or dist. with oil ,399.8 lbs with rotator 475
JAMES
Re: Engine Weights
Postby JAMES » Mon May 24, 2010 10:00 pm
U WILL NEVER GET ANYONE TO TELL THE EXACT #'S BECAUSE THEY ALL ARE WEIGHTED DIFFERENT AS IN - AND + ACC. ECT
muffled500hp
Re: Engine Weights
Postby muffled500hp » Tue May 25, 2010 8:42 am
The aluminum WaterThunder Performance LS engine weighed 396 lbs. with all accessories including starter, alternator, pulleys, and flywheel. I believe it was a fuel injected 550 hp version. The 502 aluminum head GM crate engine with accessories tipped the scales at 707 lbs.
Keith ~~
Modern Performance Engines, LLC
Custom built engines for airboats, hotrods, mud trucks, buggies, circle track and drag racing!
352-282-6407
MPEKeith@gmail.com
www.facebook.com/modernperformanceenginesllc
Waterthunder
Re: Engine Weights
Postby Waterthunder » Tue May 25, 2010 9:05 am
I have been weighing motors for years. I must start by saying we use a load cell on a strain gauge on our scale. It get's calibrated once a year and has never been off yet. Every complete small block Chevy I have ever weighed was more then 500lb's without a gearbox. I weigh all motors 100% complete. I use to post weights all the time but I got tired of having every post turn into a debate. In my pic or posts you will see GPU's, 540's, 470's, 180's, 500 Caddy's, 502 BBC, and a bunch more. I will say if you have a 18x8 Texas boat and you haul freight with it I would only go with a BBC mostly because everyone in Texas run's 2to1 or 2.38 belt drives. When you have a very big and heavy boat that you load down with 1,000's and 1,000's lbs of gear and people there is no reason to worry about a motor weighing less.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
cajun_ag
Re: Engine Weights
Postby cajun_ag » Tue May 25, 2010 10:33 am
Thanks for the replies.
The boat I have planned will be layed out internally similar to WarriorP's boat viewtopic.php?f=48&t=23967&hilit=texoma as far as deck, lights, seating, genny mount. I want a quiet as reasonable boat as well so probaly 2:68 & S blades, full exhaust ect
By Florida standards it's a tank, but I plan on having it built by GTO or Diamondback so it should be somewhat lighter than Preston's above. The lights & genny will always be on the boat, but most of the time I'll just be hauling the wife and kids that might total 200# combined. There will be occasions when it has to haul 1000# extra but that's maybe 5% of the time and I'm not really designing around that. On the rare occasion that we get to shoot 1100 fish in a night I'll be content if she still floats and idle back to the ramp. :bounce: :lol:
I'm not heart set on a SBC, but being new to AB's I'm not sure if roughly 400#s is going to get measurable results in a boat so big. Obviously I'm not building a hotrod so what would you consider a workhorse day in day out engine. A lot of guys around here run a 496 or 502. I'll stick with CI's and won't state hp #'s for obvious reasons.
Thanks again for the help
HuntingBigun
Re: Engine Weights
Postby HuntingBigun » Tue May 25, 2010 10:48 am
Each OEM has different specs on the build to compensate for weight & placement of all your goodies. GTO builds the deckover like mine but the setup is different between aluminum engine or cast iron. So for my 10 cent with a 18 foot barge I go with a FI BBC :D
Bigun
http://www.krvsa.com
http://krvsa.com/product/airboat-raffle-tickets/
Joe
Re: Engine Weights
Postby Joe » Tue May 25, 2010 11:17 am
On a boat that big a BBC would probably do you the best for longevity and reliability. Give both those manufacturers a call and talk it over with them. Both have a good engines they use if your not making a hot rod.
Compromise is for those that cant get it done!!
Equal rights for Southern Whites!
Users browsing this forum: No registered users and 23 guests
