gm502 dd vs 500 caddy dd
Bdriller
Post by Bdriller »
you are right sir thanx i meant gm 502 dd vs 500 caddy dd not sure what 502bb means? has anyone ran a gm 502 dd ?
bruceharwell
Re: gm502 dd vs 500 caddy dd
Post by bruceharwell »
bb=big block
jopete
Post by jopete »
just my opinion, but if ur gonna spend the money on gas to run a bbc, get a new or used reduction unit. it sure does make it alot more 4x4.
crowhater
Post by crowhater »
The 502 would lose. The 500 cadillac is lighter and makes much more torque then a 502 in the 0-3000rpm range.
ffcracker
Post by ffcracker »
502 is just getting into its power at 3500 rpm. You dont want to swing any prop faster than 3000. Caddy is better choice for DD.
A RESENTFULL CITIZEN OF A DICTATORSHIP CALLED alachua county
JAMES
Post by JAMES »
8.2is a 500 and the 502 cad is still a 8.2 500 :shock: if your refering to the cad motors
