lost power
riverdogs352
lost power
Post by riverdogs352 » Fri Oct 01, 2010 10:08 pm
took my chevy 350 dd out.it ran great all day and on my way in it lost alot of power but still idles fine and still sounds good when running just dont have the power now.any suggestions what to check first.has new intake and head gaskets.
JAMES
Re: lost power
Post by JAMES » Fri Oct 01, 2010 10:24 pm
did the carb take a dump????
riverdogs352
Re: lost power
Post by riverdogs352 » Fri Oct 01, 2010 11:09 pm
no carbs fine.had a little miss be i readjusted the lifters and dont hear the miss no more but still dont have the power that it did
cowtown
Re: lost power
Post by cowtown » Sat Oct 02, 2010 7:19 am
CHECK THE LIFT ON THE CAM , WITH THE VALVES NOT ADJUSTED CORRECTLY , SBC'S ARE KNOWN TO EAT THE CAM SHAFT
http://usfth.tripod.com
And Proud Of It !!!
watersports7
Re: lost power
Post by watersports7 » Sat Oct 02, 2010 9:07 am
cowtown wrote:CHECK THE LIFT ON THE CAM , WITH THE VALVES NOT ADJUSTED CORRECTLY , SBC'S ARE KNOWN TO EAT THE CAM SHAFT
its the fastest 'wearing' part in em'...
12' Predator / Lycoming 4 Cylinder / Old Skool 68x38 Stick Prop
Perfectly said by Lycoming: Some engines purr like kittens. These roar!
Re: lost power
Post by :) » Sat Oct 02, 2010 10:10 am
Yep prolly wiped the lobes out!
Bdriller
Re: lost power
Post by Bdriller » Sat Oct 02, 2010 10:14 am
they usually start barking back through carb when when lobes start going.
JAMES
Re: lost power
Post by JAMES » Sat Oct 02, 2010 10:22 am
I HAD A FEW MOTORS ACT RIGHT WHEN IDEL AND SOUND GOOD WHAT DO U NO IT WAS EITHER THE FUEL PUMP OR CARB CHECK ALL THE EASY STUFF FIRST GOOD LUCK
LOBE ON THE CAM DO WEAR BUT MAKE SURE U CHECK THE EXT. STUFF BEFORE PULLING IT APART :D
Wind Blown
Re: lost power
Post by Wind Blown » Sat Oct 02, 2010 9:19 pm
My 350 did it about 3 weeks ago. No miss sounded fine it was a hole in the piston.
The only thing I notice different was crankcase pressure.
13x7 DiamondBack-470-3 Blade H
johnnybeeegood
Re: lost power
Post by johnnybeeegood » Sat Oct 02, 2010 9:55 pm
not really enough info, did it happen all at once? gradually, but im with James easy stuff first , starting with water in fuel, fuel filter or pump.
Bdriller
Re: lost power
Post by Bdriller » Sun Oct 03, 2010 10:36 am
distributer slip to a retard position
grant
Site Supporter - VII
Re: lost power
Post by grant » Sun Oct 03, 2010 11:05 am
Wind Blown wrote:My 350 did it about 3 weeks ago. No miss sounded fine it was a hole in the piston.
Pay closer attention....and have your hearing checked!! :D :D
"Don't Taze me Bro"
JAMES
Re: lost power
Post by JAMES » Sun Oct 03, 2010 9:41 pm
:lol: yea how's that psooible it aint no cadillac :D
crowhater
Re: lost power
Post by crowhater » Mon Oct 04, 2010 2:11 pm
Don't guess at it, just pull the plugs do a leak down test. If it is hurt a leak down test will tell you real quick. There are many diffrent things you could have done to loose power, you could have burned the rings, washed the rings, killed the valve springs, killed the cam, etc, etc.
filetnrelease
Re: lost power
Post by filetnrelease » Mon Oct 04, 2010 10:39 pm
+1 on what Crowhater said... compression test is good info to have as well when trouble shooting
"Whether you think you can or you think you can't, either way you are right" Henry Ford
