gearbox help
scoobie
gearbox help
Post by scoobie » Tue Nov 16, 2010 12:39 pm
have called Precision they have not called back yet do i need standard fly wheel to bolt drive plate to looks like the drive plate would take the place of the clutch
JAMES
Re: gearbox help
Post by JAMES » Tue Nov 16, 2010 12:48 pm
scoobie wrote:have called Precision they have not called back yet do i need standard fly wheel to bolt drive plate to looks like the drive plate would take the place of the clutch
CALL WATER THUNDER DAVE I THINK HE WOULD NO FOR SURE !!!!!!!
cntry141iq
Re: gearbox help
Post by cntry141iq » Tue Nov 16, 2010 3:06 pm
The only precision boxes I ever ran had to have the flex plate drilled to fit .. maybe I always had the wrong plates don't know but they were all drilled
yobee
Re: gearbox help
Post by yobee » Tue Nov 16, 2010 3:39 pm
Post a pic... there should be a plate on the gearbox that bolts to the flexplate of the engine... At least that's how stinger and rotators work...
Gary Gilbert
Re: gearbox help
Post by Gary Gilbert » Tue Nov 16, 2010 3:51 pm
Yes you have to have the Flex Plate drilled. I just got through replacing ours due to worn down teeth from a bad starter drive. I used the old one as a guide template. I have had problems getting with Precrision myself. We just keep calling till he was at home, they do offer predrilled flex plates. We just choose to drill ours because we had another flex plate already.
Go Bug
skinny99
Re: gearbox help
Post by skinny99 » Tue Nov 16, 2010 6:37 pm
My flex plate on my Precision box is drilled. Works fine. However I think if I was to mate one to a big HP motor I would reinforce the holes I drilled. IMO
scoobie
Re: gearbox help
Post by scoobie » Wed Nov 17, 2010 9:02 am
im going to drill the holes thanks guys
C1gator
Re: gearbox help
Post by C1gator » Wed Nov 17, 2010 2:33 pm
Drill the flexplate and ride out....I met Vaughn at precision one time....He is a one man operation, and from what I can recall he is quite fond of hunting, so he very well could be up a tree as I type this....Very nice guy with a lot of knowledge...Pretty sure he said most of his boxes go on planes, but he does sell a lot to the airboat industry.....
