advice on motor choice
rjfjr
Post by rjfjr »
i was out riding wednesday when my lower end let go on my 350 chevy 275hp it is unfixable because of the new hole in the block it is on a 14' gillio w/poly @ afranklin 2to1 belt drive running a 3 blade sensinche my question is i found a 305 ho and a 400 complete motors i use the boat for fishing and just riding usually just 3 of us i'm not looking for a race boat just a fun boat p.s. ya this is my first airboat b.o.a.t. :banghead: :banghead:
bruceharwell
Re: advice on motor choice
Post by bruceharwell »
That 305 won't make a good anchor IMO.
anvil
Post by anvil »
THE ONLY FUN BOAT IS THE ONE THAT DOSENT GET STUCK GO WITH THE 400
The company of men who seek the truth is much prefered to those who think they have it
Ride boat 14 ft Don Davis Davis sled iron sbc
rjfjr
Post by rjfjr »
thanks for your opions ifigured the 400 would be a better choice do u think it is ok to run 2 bolt mains or should i only run 4 bolt 400 block thanks again
cntry141iq
Post by cntry141iq »
two bolt will be fine ... there are a lot of good old threads on here about the 400's so use the search feature and settle in and start readin ...
rjfjr
Post by rjfjr »
thanks guys big help
akblackdawg
Post by akblackdawg »
you might also consider looking for a 454, more torque. Bud
RiseAboveIt
Post by RiseAboveIt »
The old saying... No replacement for displacement....
No matter what happens... Just Rise Above It.
watersports7
Post by watersports7 »
12' Predator / Lycoming 4 Cylinder / Old Skool 68x38 Stick Prop
Perfectly said by Lycoming: Some engines purr like kittens. These roar!
