What does a motor weigh?
SWAMP SHAKER
Post by SWAMP SHAKER » Sat Mar 26, 2011 12:59 pm
I'm hoping somebody can tell me how much a SBC weighs. It's a 383 completely dressed... Carb, dist. pulleys, ect. Everything but headers. Thanks in advance!
16'X8' ALUMINUM BARGE, 397 FELBER POWERED, 2.55 POLISHED STINGER, SENSENICH 82" 3 BLADE "R"
GET ON, SIT DOWN, SHUT UP, & HOLD ON!!!
GIVE EVERYTHING YOUR ALL..THAT'S ALL YOU CAN DO, AND IF THATS NOT GOOD ENOUGH....F@CK EM
Maxx121
Re: What does a motor weigh?
Post by Maxx121 » Sat Mar 26, 2011 1:21 pm
aluminum or iron heads?
15x8 SUPERCHARGED LS PANTHER LIGHTNING
2.68 ROTATOR 80" 3 BLADE R'
Kpeterson
Post by Kpeterson » Sat Mar 26, 2011 1:25 pm
If its all iron id say between 500-600 lbs. Minus somewhere around 80 pounds if you have aluminum heads.
BigJakesrq
Post by BigJakesrq » Sat Mar 26, 2011 1:25 pm
With iron heads around 500
SWAMP SHAKER
Post by SWAMP SHAKER » Sat Mar 26, 2011 2:16 pm
Aluminum heads, iron block. So approx. 500 lbs? Probably gonna need more than two people to get it in the truck!!! :scratch:
SouthRiver
Post by SouthRiver » Sat Mar 26, 2011 8:12 pm
Two average people should be fine :salute:
"It is what it is......and...... "Everything happens for a reason, whether you like it or not......."
New boat is in the works..............
BCAA Member
N.R.A. Lifetime Member
JAMES
Post by JAMES » Sat Mar 26, 2011 9:39 pm
if u got nuts and no acorns u can do it.. me and a buddy my sz picked my caddie up and put it in my dodge ram bed that had 36"tires and a 6" lift im a big young strong guy i guess that helped :wink: u should do fine lift with your knees not your back lol keep them nuts swingin :lol:
Kpeterson
Post by Kpeterson » Sat Mar 26, 2011 11:43 pm
Work smarter not harder, if you got a lift use it, dont risk your back its not worth it.
watersports7
Post by watersports7 » Sun Mar 27, 2011 8:49 am
12' Predator / Lycoming 4 Cylinder / Old Skool 68x38 Stick Prop
Perfectly said by Lycoming: Some engines purr like kittens. These roar!
Airboat Hunter
Post by Airboat Hunter » Sun Mar 27, 2011 9:27 pm
a Iron head sbc is around 525 give or take. i Have a Iron head SBC 383 on my airboat .
14'x7' Alum/355/2:1 Belt/3 Blade WW stumppuller.
watersports7
Post by watersports7 » Mon Mar 28, 2011 7:58 am
Airboat Hunter wrote:a Iron head sbc is around 525 give or take. i Have a Iron head SBC 383 on my airboat .
with any type of reduction, your looking at an 'easy' 600 pounds.
Airboat Hunter
Post by Airboat Hunter » Mon Mar 28, 2011 10:22 am
My motor and my ch3 belt is around 650+ lbs. I have it on a 13x7 alum hull
mudkat
Post by mudkat » Mon Mar 28, 2011 10:09 pm
400 sbc alum heads and water pump.no carb or dist. with 2.68 rotator drive 473 lbs on my certified digital scale.
