figuring horsepower
undicided
figuring horsepower
Post by undicided » Fri Dec 02, 2011 5:37 am
anyone know a good website for figuring horsepower and torque, googled last night but had no luck just wanting to get a estimate of what I have.
speed wheelie
Re: figuring horsepower
Post by speed wheelie » Fri Dec 02, 2011 7:32 am
Lie = Lycoming ...So don't believe what thy tell you!!!!!!!
You got to be yourself
863-956-3030 shop and cell
flying fish
Post by flying fish » Fri Dec 02, 2011 8:31 am
You can go to these websites and try to match your build. Could be close.
http://www.airflowresearch.com/chevy_dyno.php
http://shafiroff.com/
akblackdawg
Post by akblackdawg » Fri Dec 02, 2011 12:12 pm
Most likely you will be happier from talking to the guys at the boat ramp, they all seem to know it all. Bud
terrible ted
Post by terrible ted » Fri Dec 02, 2011 12:50 pm
That true them manufactures never know what the hell there talking about.
YELLOWHAMMER
Post by YELLOWHAMMER » Fri Dec 02, 2011 1:14 pm
pm me the size of motor the type of cam an specs size of cylinder heads intake an carb size an brand
THE EDUCATION OF A MAN IS NEVER COMPLETED UNTIL HE DIES GEN ROBERT E LEE :rebel:
cowboy
Post by cowboy » Fri Dec 02, 2011 1:15 pm
Tonto try to use Kemosabe calculator to figure power of his fire breathing single mag ground power war horse.
After many trials of failed countings, Tonto come to see that no calculator can show so great a number, as it is the power equal of a great many bold horses that Tonto ground powered war horse produce.
It has taken lumber of many great trees to restrain Tonto Fire Breathing Ground Power War Horse from galloping to RPM levels, that only the great spirit can see the height of.
Such power is a great gift to Tonto, so much power that Kemosabe wise and powerful calculator can not even comprehend.
Tonto now no longer worry. Tonto only proud knowing of the great sound of thundering single mag galloping war horse, that Kemosabe can hear from distances greater in length than the longest rivers of life .
harley
Post by harley » Fri Dec 02, 2011 1:49 pm
You can call Summit & Jegs, and ask to talk to a tech and give them your parts list your motor is built with, they will get you close to your hp and torque specs ...
:thumbleft: :rebel:
14x8 Diamondback / SBC Power.
"ALL THROTTLE NO BOTTLE"
bondsman
Post by bondsman » Fri Dec 02, 2011 3:19 pm
some one will help you on here.we have a bunch of mechanical magicians on here.they can pull numbers out of there a$$ like you wouldnt believe.
Tony480
Post by Tony480 » Fri Dec 02, 2011 3:35 pm
bondsman wrote:some one will help you on here.we have a bunch of mechanical magicians on here.they can pull numbers out of there a$$ like you wouldnt believe.
Just ask Dave! LMAO! :D
makinwaves
Post by makinwaves » Fri Dec 02, 2011 3:39 pm
measure the length of the block, and multiply the girth of the block and divide by how many "beverages" it took to build it.
cowboy
Post by cowboy » Fri Dec 02, 2011 4:11 pm
ALL YOUR HORSEPOWERS ARE NOW BELONG TO US!!!!
todd glover
Post by todd glover » Fri Dec 02, 2011 6:05 pm
Pull the motor and dyno 150$ later you'll know you have alot less than you think that's better than guessing
JAMES
Post by JAMES » Fri Dec 02, 2011 6:47 pm
todd glover wrote:Pull the motor and dyno 150$ later you'll know you have alot less than you think that's better than guessing
A MOTHER FKING MEN ...
Tony480
Post by Tony480 » Fri Dec 02, 2011 7:56 pm
Who the hell is going to let you use their dyno for $150???? Nobody in this world.Most get at least $500.
Whitebear
Post by Whitebear » Fri Dec 02, 2011 8:49 pm
skinny99
Post by skinny99 » Fri Dec 02, 2011 9:01 pm
I want the name and number of the guy for $150. Most are $500 plus...
Tony480
Post by Tony480 » Fri Dec 02, 2011 9:05 pm
No shiat!!
todd glover
Post by todd glover » Fri Dec 02, 2011 10:04 pm
If you know someone it's 150 for me I don't care what it cost you but that's the only way to know what you got I'm sure one of you experts can just look at it and tell what it makes hehehe
dusty burch
Post by dusty burch » Fri Dec 02, 2011 10:27 pm
there is a download called desktop dyno punch in all specs and get results
blown480
Post by blown480 » Fri Dec 02, 2011 10:31 pm
call "DAVE' he will dial , type in whatever #'s you need on that firebreather,
mrfixit
Post by mrfixit » Fri Dec 02, 2011 11:05 pm
I've used several computer dyno programs in the past with good results .not in knowing horsepower but in checking changes to see what it could do. there will always be variables, timing, air density, fuel and a lot of other things.
Is this a auto engine or aircraft?
With the auto atleast there are tons of builds and info. On the the aircraft there seams to be a lot less info. Plus there is a ton of mixed manufacturers engines using lycoming, continental , and an array of handmade parts.
Plus how will you check the heads for flow and the engines volumetric efficiency .
undicided
Post by undicided » Sat Dec 03, 2011 5:59 am
sent you info yellowhammer
poobought
Post by poobought » Sat Dec 03, 2011 6:57 am
To get a price like that you will most likely have to know someone that owns
a dyno because nobody dynos them that cheap. I paid 200.00 for mine to be dynoed and have known the owner for several years. He normaly gets 500 to 700.
If you know all the motor specs then post them. There are some very smart people on here that can give you a real close educated guess/estimate of your horse power. It will be just that, a guess but it will give you a close idea of what you have. You will also have to weed thru some a$$holes to get to the good ones but thats always the case.
undicided
Post by undicided » Sat Dec 03, 2011 6:59 am
thanks to all who make a valid effort to help out
