Help Needed
Clint Hall
Help Needed
Post by Clint Hall » Sat Jul 20, 2013 8:33 pm
Well bought a motor and gear box off here trying to get this boat done before winter. Checked cyl pressure before I handed the guy the money all eight cyl were from 140 to 150psi. W/ 65psi of oil pressure. Decided to put new valve cover, oil pan, timing, front crank and rear main seals in it before it went in the boat because I hate leaks!!! Dropped the oil out of it and whamooo bout a 1/4 quart of antifreeze in the pan. This is a vortech headed small block. Any ideas before I tear it completely down?? Possible intake gasket? This just made for a really crappy weekend
2013 14'x7.6' wide nose gilileo. 355SBC 2.38 stinger 78" 10blade warp
onlyone
Re: Help Needed
Post by onlyone » Sat Jul 20, 2013 9:24 pm
From what iv read the vortec heads are prone to crack. I had water in my 4 and 6 cylinder and in my 7 cylinder. Had um checked and both heads were cracked. Not sayin thats your problem but I would have them checked.
16x8 Classic, 383 sbc 425 hp, 2.68:1 Rotator, & 80" 3 blade Whispertip
Member of IRCAA http://indianriverairboat.com/
If you don't know where your goin you might end up somewhere else.
darrell
Re: Help Needed
Post by darrell » Sat Jul 20, 2013 10:17 pm
I would try a leak down test on all cylinders and see if you can determine where the problem is
if you argue with an idiot who is the real idiot
12x7 traditions hull Moore built av540 74" ww
anahuacbound
Re: Help Needed
Post by anahuacbound » Sat Jul 20, 2013 10:26 pm
Definately do a leak down test. Let us know what you find.
15x8 GTO, LS3, CH3 Belt, 3 Blade Whisper Tip
crowhater
Re: Help Needed
Post by crowhater » Sat Jul 20, 2013 11:48 pm
Name the guy that sold it so he can't screw anyone else over
Clint Hall
Re: Help Needed
Post by Clint Hall » Sun Jul 21, 2013 1:32 am
Can't do that bro it's the way I think it should be..lesson learned I guess!!!
mike99705
Re: Help Needed
Post by mike99705 » Sun Jul 21, 2013 2:24 am
I would have to wonder if this guy knew about this or not. I would talk to him and work it out. If he is a stand up guy you could come to a happy ending. If not then he sold you something that was not as advertised. talk to him and let us know the outcome. Hopefully your response will not be sent to thread heaven if the guy tried to screw you.
8 x 15 alumitech 383 mas from gto 3 blade r 2.3 belt
flying fish
Re: Help Needed
Post by flying fish » Sun Jul 21, 2013 7:43 am
Yes, possibly intake gasket. Like you said.
Fatigue. Nobody's fault.-
Clint Hall
Re: Help Needed
Post by Clint Hall » Sun Jul 21, 2013 9:44 am
I honestly don't believe the seller had any idea of it. It's no offense to the guy but I don't think he was too mechanically inclined
flying fish
Re: Help Needed
Post by flying fish » Sun Jul 21, 2013 4:30 pm
After you get Coolant in Oil Pan issue resolved, would be interesting to see what your cranking cylinder pressure is after she has ran for a bit.
Equally, 140-150 is good being that all cylinders are near same.
140-150 seems low for static cranking pressure.
Battery, starter, or just has not ran for a long while. All could be possibilities of why cranking pressure is 140-150?
When you checked cranking pressure on all cylinders, did you open up the throttle plate(s)?
Clint Hall
Re: Help Needed
Post by Clint Hall » Mon Jul 22, 2013 4:20 pm
Well both heads are junk! Talked to the guy I bought it from and he is insistent that it never ran hot or had any problems. Lesson learned I guess I now have a really expensive gear box! I can't figure out how some ppl sleep at night!!
flying fish
Re: Help Needed
Post by flying fish » Mon Jul 22, 2013 4:34 pm
Dang it man. Crowhater was right.
Hate to see you meet a less than honest person.
Clint Hall
Re: Help Needed
Post by Clint Hall » Mon Jul 22, 2013 5:15 pm
Gotta try to round up another motor now. I would be completely happy with a stock motor for now till I can recover financially from all of this. Any suggestions for a feller on a tight budget!
skinny99
Re: Help Needed
Post by skinny99 » Mon Jul 22, 2013 7:14 pm
http://www.summitracing.com/parts/sum-151124/overview/
You need a set of heads not an engine. Brand new castings and "SHOULD" fit your existing components.
Clint Hall
Re: Help Needed
Post by Clint Hall » Mon Jul 22, 2013 7:58 pm
The bottom end is pretty tired also. Turns out the motor is out of a 97 Tahoe. Seems the general consensus it to not waist the money on a 2 bolt main block. I'm a mopar guy and I have personally twisted the crap out of some 440's and never had an issue w/ mains but I'm not a Chevy guy so I stick to the norm.
Clint Hall
Re: Help Needed
Post by Clint Hall » Mon Jul 22, 2013 8:01 pm
I really appreciate all the input tho!
mike99705
Re: Help Needed
Post by mike99705 » Mon Jul 22, 2013 8:07 pm
Sorry to hear about your situation, It sucks. Hpefully you can find a junkyard special to hold up untill you can get a motor built.I assume the guy has washed his hands of the matter. Did he represent it as a strong healthy motor?
00
Re: Help Needed
Post by 00 » Mon Jul 22, 2013 8:23 pm
I am selling the motor on my boat complete running motor distributor,pulleys,water pump,headers,with or with out carb.can hear run and test ride still on boat.very strong aluminum headed small block Chevy $3500.00 with carb/$3000.00 with out 386 804 0157
00
Re: Help Needed
Post by 00 » Mon Jul 22, 2013 8:25 pm
Forgot to mention it is hooked to 2.09 stinger and 80" 2blade on a 14 ft glass hull
Clint Hall
Re: Help Needed
Post by Clint Hall » Mon Jul 22, 2013 9:41 pm
Kinda out of money now bud. So it's back to the drawing board. And yes the motor was advertised as healthy. Now I remember why I usuall build my own stuff.
