cam question 355 lt sbc
aggiejim
Postby aggiejim » Mon Nov 04, 2013 11:57 pm
I am putting together a 355 lt 2/1 beltdrive 2 k blade prop this is a roller motor I had laying around my shop and it needed a job
flat top standard compression carb intake
a 16/7 pathfinder stainless cage and rigging kinda heavy
I am not scared to have a custom grind from cc but there should be one out there
:fishing
16 x 8 floral city ls2 6.0 aluminun block 2.3 ch3
can u say addicted
16.5 x8 alumintech new build
6.0 ls2 2.3 ch3 3 blade
the aggie
skinny99
Re: cam question 355 lt sbc
Postby skinny99 » Tue Nov 05, 2013 6:18 am
With a 2:1 box I like this cam.
http://www.compcams.com/Company/CC/cam- ... =1107&sb=2
Set it about 5300 on trailer. Them "K" blades need a little tip speed.
todd glover
Postby todd glover » Tue Nov 05, 2013 6:19 am
Yeah call comp with all your info
JAMES
Postby JAMES » Tue Nov 05, 2013 6:42 pm
howards cams jmo
Gangreen
Postby Gangreen » Tue Nov 05, 2013 7:55 pm
The chevy hot cam for their roller motors lt1 to lt4. Chevy made it so it has to fit better than anything else.
skinny99
Postby skinny99 » Tue Nov 05, 2013 8:00 pm
Gangreen wrote:The chevy hot cam for their roller motors lt1 to lt4. Chevy made it so it has to fit better than anything else.
A truly ridiculous statement in a thread about what cam may work well in an airboat. I am sure GM has spent many an hour trying to make
an engine perform well in that kind of application with highly modified intake and exhaust systems. :roll: :scratch:
Gangreen
Postby Gangreen » Tue Nov 05, 2013 8:38 pm
That's really funny because I run that cam. Why does people think an airboat with any kinda reduction needs a special cam? I am old school and all these ideas that people think wont work will work. Ill bet now I hear a Buick motor wont work for DD.
loudmouse
Postby loudmouse » Tue Nov 05, 2013 8:50 pm
Determine the speed you want to spin the prop. Use ur gear ratio to get required engine rpm for that prop speed. Get all the specs to ur engine and call John @ bullet racing cams. They will give you a very good cam to meet ur engine needs.
14'X8' JW, Chevrolet 122CID LNF Turbo Engine, Ox box, 80" NGR 3 blade, 50" light bar, Two 9" light bars, some long ropes, extra gas(for my buddies)with pushpole and paddle. LOL
aggiejim
Postby aggiejim » Tue Nov 19, 2013 3:06 pm
went a little over the top went with a comp ex energy 510 lift with 1.55 rockers behive springs max lift with pistons 10.7 compression flow benched the heads matched every thing up 650 elderbrock with el choke msd ign 5800 rev lim waiting on headers and motor mounts from poboys to start motor should be 430hp hull is ready lookin for something cool for rudders (art)
can u say addicted
the aggie
