backfiring threw the carburator
lucus308
Post by lucus308 » Sun Jan 05, 2014 8:25 pm
im at my wits end with this backfiring problem. since this problem has shown up i have check everything i can think of i changed spark plugs and wires put a new distributor cap and coil. had the carb rebuilt. shot the timming and checked the fuel pickup and fuel pump i also checked for leaks around the carburator and still cant find the problem. im running a 383 stroker with 550 hp and it has a holly 750 double pumper. everything has been great on this motor since i have bought it. i notice that it was taking more rpms to get my boat up on plane and thats when i found this issue and it only backfires in the front two barrels. any help with this will be greatly appreciated.
yobee
Re: backfiring threw the carburator
Post by yobee » Sun Jan 05, 2014 8:38 pm
An intake valve is open when the cylinder fires. Go through your valves. Lots of info online how to adjust them.
victorg
Post by victorg » Sun Jan 05, 2014 10:16 pm
X2 on adjusting the valves. If they are not right it will pop through the carb or worst wipe out the camshaft.
HAMMERHEAD
Post by HAMMERHEAD » Mon Jan 06, 2014 7:27 am
make sure you didnt get a plug wire crossed as well! dont overlook the simple suff.
air-roberts
Post by air-roberts » Mon Jan 06, 2014 7:45 am
could be a broken valve spring
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
flying fish
Post by flying fish » Mon Jan 06, 2014 7:54 am
Lean on the primaries? What your plugs saying?
Possibly one side of primary carb squirter plugged.-
plug fouling due to rich circuitry?
lucus308
Post by lucus308 » Mon Jan 06, 2014 8:26 am
All the plugs look like new and the plug wire are in the right spots going today to get the lash checked on the valves. Thanks for the help I'll let y'all know the outcome
gatorbait1989
Post by gatorbait1989 » Mon Jan 06, 2014 9:03 am
Could be power valve in the carb
ddriver
Post by ddriver » Mon Jan 06, 2014 9:03 am
do a comp. test. that may give you he answer.
lucus308
Post by lucus308 » Mon Jan 06, 2014 5:13 pm
Found the issue it was a bad rotor in the distributor thanks for the advice.
victorg
Post by victorg » Mon Jan 06, 2014 6:25 pm
Sounds like a few dollar fix. Thanks for posting what was wrong.
PoorboysAirboats
Post by PoorboysAirboats » Mon Jan 06, 2014 9:39 pm
Sounds to me it was a bad cap and two wires crossed! Glad we help get you back going.
William Sikes
Poorboy's Performance Airboats
352-356-9057
http://www.poorboysperformanceairboats.com
Poorboysperformanceairboats@yahoo.com
Post by John Fenner » Mon Jan 06, 2014 11:20 pm
So, how far did the backfire throw the carb anyway? Chuckle chuckle! Glad you fixed it!
Post by :) » Tue Jan 07, 2014 4:53 pm
I know he got it fixed but just to add, mine was doing simular things awhile back. I went through all that mentioned above then took it to someone.. ended up being bad gas and it had junked my edelbrock.. a holley and fresh gas.. what an idiot i felt like. I had tried a different carb when trying to solve it my self and had some improvement but it still wouldnt run right.. lucky for me there was only a few gallons left that i had to empty out.
keebo
Post by keebo » Tue Jan 07, 2014 7:56 pm
lucus308 wrote:All the plugs look like new and the plug wire are in the right spots going today to get the lash checked on the valves. Thanks for the help I'll let y'all know the outcome
PoorboysAirboats wrote:Sounds to me it was a bad cap and two wires crossed! Glad we help get you back going.
HAMMERHEAD wrote:make sure you didnt get a plug wire crossed as well! dont overlook the simple suff.
Never forget the small stuff, check and check again. glad ya got it fixed.
:old_glory: :florida: :GA:
