5.3LS ??
Superduty88
5.3LS ??
Post by Superduty88 » Fri Jun 20, 2014 10:25 am
Hey guys im in the process of putting my boat together its a 12x8 aluminum step deckover I got a 2007 5.3 LS it had 60 thousand miles when it was pulled its a very clean motor.. I know a lot of guys might disagree with me but im going with a carburetor i got the intake MSD ignition and the carb already but im wanting to put a cam in it nothing crazy something just to give it a few more hp more then likely ill have a rotator 2.12 not sure what prop yet.. any info would be appreciated :florida:
12x8 Aluminum deckover step with a LS2 2.37 rotator 78 3blade R
11x7 Aluminum sled fresh 0435 6 blade warp
jaxduramax
Re: 5.3LS ??
Post by jaxduramax » Fri Jun 20, 2014 10:39 am
Is that motor going on that deckover you've had in the classifieds?
scottyroll
Re: 5.3LS ??
Post by scottyroll » Fri Jun 20, 2014 10:42 am
2 blade "R" or whirlwind whisper tip should do well with that motor and box combo. Feel free to contact any of the prop manufactures - all of them produce great products and strive for top notch customer service to all airboaters. There are several threads on cams for these engines if you search for them. Nothing wrong with running a carb on that setup either. You should have your self a good rig when your done 8)
:Scotty-Roll:
FLAwless
Re: 5.3LS ??
Post by One Eyed Gator » Fri Jun 20, 2014 11:02 am
I would do a little reading there is a lot of info out on cams. Article indicates that most after market cams do produces more HP and torque but over rpm an airboat motor usually turns.
I know you can not believe everything you read. Check out the article below. Just food for thought.
http://www.carcraft.com/techarticles/13 ... omparison/
We a 99' 5.3 on a buddies boat with a 2.68 and 78" Maximus. thing was way over pitched but was a tractor would tun a 42. Boat was and older heavy alumitec deckover.
Gonna a 2.55 box and building a cage for a bigger prop. I was very impressed with the bone stock 5.3 and got great of fuel consumption.
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Fri Jun 20, 2014 11:45 am
jaxduramax wrote:Is that motor going on that deckover you've had in the classifieds?
No I bought a new boat
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Fri Jun 20, 2014 11:53 am
Iv been reading a lot on them a lot of guys have different opinions thats for sure...I was just seeing if anyone on SA has close to the same set up on there boat that I'm doing and if they are running a different cam if so what one did you go with
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Fri Jun 20, 2014 11:58 am
This is the boat it's going on
Bagman
Re: 5.3LS ??
Post by Bagman » Fri Jun 20, 2014 12:45 pm
If it was me, i would definitely get a custom cam, hardened pushrods, and change the valve springs at a minimum. I use Cammotion for my cams. Let me know if you have any more questions
14 x 7' 10" DynaMarine Velocity, 2.5 Ballistic gear drive, Supercharged LS, 3 blade NGR
Whiplash Performance Marine
ls1airboat
Re: 5.3LS ??
Post by ls1airboat » Thu Jun 26, 2014 7:07 am
ill be changing the cam , pushrods and springs in mine
ptr34
Re: 5.3LS ??
Post by ptr34 » Thu Jun 26, 2014 11:15 am
2 blade NGR 78"
tons videos on YouTube ptr34
Birddog247
Re: 5.3LS ??
Post by Birddog247 » Thu Jun 26, 2014 11:34 am
ptr34 wrote:2 blade NGR 78"
Couldn't agree more. Just recently went to a 2 blade ngr 80" on a similar setup. Great performance all around.
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Thu Jun 26, 2014 1:02 pm
That's the blades I'm shootin for
gso480jr
Re: 5.3LS ??
Post by gso480jr » Thu Jun 26, 2014 4:54 pm
Is that ls 5.3 a d.o,d,/afm motor? if yes, be prepared to spent money on lifters, cam, delete kit and you will have a good start.
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Thu Jun 26, 2014 9:44 pm
It's was pulled from a 07 chevy pickup truck not sure if it's DOD or not I plan on putting money in it to make it right this is my first ls motor I'm use to dealing with the old sbc so I'm kinda learning as I go
gso480jr
Re: 5.3LS ??
Post by gso480jr » Thu Jun 26, 2014 9:51 pm
look at valley cover under intake. do you see an electrical connection on the left rear?
ls1airboat
Re: 5.3LS ??
Post by ls1airboat » Tue Sep 02, 2014 12:07 pm
hey ..hows the boat comming along ?
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Mon Sep 08, 2014 3:16 pm
ls1airboat wrote:hey ..hows the boat comming along ?
It's comeing we just finished my brothers boat so it's my turn to get mine going now....
But I have one more question for you guys what carburetor would y'all recommend for that motor its pretty much stock for now I was thinking a quick fuel 650 but not sure if it's gonna be to small or what thanks for the input :florida:
scottyroll
Re: 5.3LS ??
Post by scottyroll » Mon Sep 08, 2014 3:26 pm
My Holley 600 worked well. I don't see why even a 500 wouldn't work well after a tune up. no sense and spending more on gas :blackeye:
:Scotty-Roll:
FLAwless
ls1airboat
Re: 5.3LS ??
Post by ls1airboat » Mon Sep 08, 2014 3:44 pm
i can get the ecm and the efi done for pretty cheap...mine is running perfect now ..real strong even with a stock tune.
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Mon Sep 08, 2014 3:54 pm
Sweet that sounds good enough for me thanks Scotty
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Mon Sep 08, 2014 3:57 pm
ls1airboat wrote:i can get the ecm and the efi done for pretty cheap...mine is running perfect now ..real strong even with a stock tune.
It's to late now I got all my stuff for the motor just lacking carb and headers ill deff will call you on the next boat.. Next one is definitely gonna be EFI
ls1airboat
Re: 5.3LS ??
Post by ls1airboat » Mon Sep 08, 2014 4:05 pm
i got ya...ill be ready to ride in about 2 weeks or so
Superduty88
Re: 5.3LS ??
Post by Superduty88 » Mon Sep 08, 2014 4:17 pm
Nice I'm shooting for mid October the wife wants us to be on the river for her birthday...looks like I better get off southern airboat and get to work :scratch: lol
ls1airboat
Re: 5.3LS ??
Post by ls1airboat » Mon Sep 08, 2014 4:20 pm
you better lol..
